Code C1241
Old Feb 16, 2006 | 06:37 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Default Code C1241
Anybody ever have this code?Its something about the magna steer.I checked the wiring,Where the wires plug into and nothing.No blown fuses,Tried resetting the code,but comes back up.
Old Feb 16, 2006 | 11:52 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
ttt
Old May 4, 2006 | 04:39 PM
eggrock's Avatar
eggrock
Cruising
I seem to have the same issue with my '00 FRC. Same code and keeps coming up.
Have you been able to resolve it?
Old May 4, 2006 | 05:02 PM
Gray Fox's Avatar
Gray Fox
CI 5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08-'09
C1241 Magna Steer Circuit Malfunction
Full list of codes here:
http://www.stengel.net/diccodes.htm
Old May 4, 2006 | 06:34 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The Speed dependent Steering System (MAGNASTEER) incorporates its controller into the EBTCM. The EBTCM controls the amount of current supplied to the MAGNASTEER actuator based on input from the wheel speed sensors and based on the steering wheel position sensor.
One or both of the MAGNASTEER actuator circuit wires become open or shorted.
A malfunction DTC is stored. No ABS/TCS indicator lamps are turned ON but MAGNASTEER is disabled. ABS/TCS remains functional.
A history DTC will clear after 100 consecutive ignition cycles if the condition for the malfunction is no longer present.
The On-Board Diagnostic (clearing DTCs) feature
Using a scan tool
The following conditions may cause an intermittent malfunction to occur:
A poor connection
A rubbed through wire insulation
A broken wire inside the insulation
Check the frequency of the malfunction by using the enhanced diagnostic function of the scan tool. Refer to Enhanced Diagnostics
Check the following for all circuitry suspected as causing the intermittent complaint:
Check for backed out terminals
Check for improper mating
Check for broken locks
Check for improperly formed terminals
Check for damaged terminals
Check for poor terminal to wiring connections
Check for physical damage to the wiring harness
Old May 4, 2006 | 08:47 PM
eggrock's Avatar
eggrock
Cruising
Thanks, Talon90.
I guess I'll be doing some searching for all the wiring related to the magnasteer circuit. Would you know of any specific connections that might be prone to fail so I can check them first?
Old May 4, 2006 | 08:56 PM
talon90's Avatar
talon90
NCM Ambassador
Originally Posted by hjegger
Thanks, Talon90.
I don't but I can try to post some diagnostic details from my service manual in the morning.
Old May 5, 2006 | 05:59 AM
talon90's Avatar
talon90
NCM Ambassador
Here is a little more info from the service manual. Hope it helps.
Paul
File Type: doc
Old May 5, 2006 | 10:44 PM
eggrock's Avatar
eggrock
Cruising
Thanks again.
I checked some of the connectors and wiring but it seemed okay.
At least I know now that it's not an important issue which needs to be fixed right away.
I'll have the mechanic to run a diagnostic next time I bring the car in.
To Code C1241
