Alternator Problem??? Help Please!!!
Old Mar 1, 2006 | 06:03 PM
  #41
rrichar2591's Avatar
rrichar2591
Originally Posted by schtick
I just got back from my "nice day cruise" and no problems whatsoever. The voltage stayed at 14.4 the whole time. I shut it off once and it sat for probably an hour and a half, went out to the car and it showed 12.3 on the DIC before I started it. Hopefully, it will be fine now. Should I disconnect the battery if I end up not driving it for a while? What do you recommend?
You really need to follow the advice from these other postings. Invest in a battery maintainer at Sears or Pepboys etc. They will run you around 30 dollars. Make sure the battery is fully charged. You can do that without disconnecting the terminals. Once you know the battery is FULLY charged, drive it and see if you get the same results you have been getting. If the car runs fine from then on, you can suspect a low battery or loose battery connections may have caused the problem. If it contines to run down and not start, I would then have a test on the electrical system done as was suggested above. Good Luck
Old Mar 1, 2006 | 06:20 PM
  #42
schtick's Avatar
schtick
Before I took it out today I took a wire brush to both of the cables to get them shining real good. I guess maybe it had that slight film on it like you said. There wasn't really any corrosion on it. I had cleaned it off the other day and there may have been a slight bit left over so that's why I used the wire brush today. I guess I'll try to get ahold of one of those battery tenders to help keep it up. I'm going to leave it like it is and see what happens in the morning. It might turn out that all of this mess that I thought I was in was actually something small like a dirty cable. I greatly appreciate everyone's help by the way.
Old Mar 1, 2006 | 06:39 PM
  #43
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
That terminal connection is very neat and tidy connection. But if you think about it there's a bolt that turns inside something that you can't see. If there is corrosion in there, you can't see that either. That's why I got digging in there and found corrosion. Also whoever tightened up the connection didn't do it correctly. You'll notice that there are dimples on the battery and protrusions on the cable connection. When you're tightening the bolt into the battery and getting close to it being tight you must twist the cable to engage the dimples in the battery connection. The person who tightened my wife's terminal connection didn't twist the connection to engage the dimples. Poor connection, actually a really bad connection. Once I cleaned it all out and tightened it down I could feel the whole connection move. It must have warped the ring inside the cable connector after being tightened improperly. I also used some dielectric grease everywhere I could to ensure a good seal. Let's hope this is your problem.
Old Mar 1, 2006 | 07:16 PM
  #44
schtick's Avatar
schtick
I see. I didn't notice the dimples and I'm not sure that this battery has them. I'll check and see and I think i may have a little bit of dielectric grease too. I'll throw some of that on there. Thanks.
Old Mar 2, 2006 | 10:04 AM
  #45
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Stock Man is on the money with the dialectric grease. Don't be stingy with it (but don't make a mess.)
Old Mar 2, 2006 | 03:49 PM
  #46
schtick's Avatar
schtick
I drove it again today and everything went fine. No problems whatsoever. I guess maybe I just overlooked a very small detail-the battery cables. Thanks again for everyone's help.
Old Mar 2, 2006 | 03:51 PM
  #47
schtick's Avatar
schtick
Oh yeah. I got a battery maintainer last night. Should I use this thing every day or just when it's going to be sitting for a while. Another thing, it has lights on it that indicate whether it's charging, charged, or dead. If you leave the thing on when it is already fully charged, will it reduce the battery's life, kinda like a cell phone does (supposedly)?
Old Mar 2, 2006 | 03:56 PM
  #48
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If its a maintainer/ trinkel charger,,, it should be automatic. If the battery is charged,, it will go static until it senses that the battery needs to be charged. I wouldn't attach it if the car is only going to be down for a week or two. Mine has been layed up for 2 months at a time without any starting issues! Leaving a trinkel charger on the battery (low amperage i.e. 1-2 amps will not damage a lead acid battery!
BC
Old Mar 2, 2006 | 05:02 PM
  #49
Stock Man's Avatar
Stock Man
Hi, I am glad you seem to have rectified the battery thing. Your maintainer can be left on 24/7. I put it on when the battery comes out every winter and when the car will sit for a week or more. Good luck man I am glad we could help you out.
Old Mar 2, 2006 | 07:09 PM
  #50
schtick's Avatar
schtick
Thanks again fellas. Where can I get some of those chrome brake pad covers, Stock Man?
Old Mar 2, 2006 | 08:47 PM
  #51
Stock Man's Avatar
Stock Man
I got mine from Corvettes "N" More. But they are no longer a forum vendor. But I think Westcoast Corvette's sells them. They are Stainless Steel Brake Pad Covers. Hope that helps.
Old Mar 2, 2006 | 10:20 PM
  #52
rrichar2591
It will not reduce the battery life, just the opposite. It will extend it. If you bought the Sears, when you first hook it up, you should get a yellow/amber type light. As the battery become fully charged, it will turn green. I keep mine on most of the winter during cold weather and when the car will not be run for more than a few days. I don't use it in the summer when it is driven more oftern. Glad you found the problem. It's a lesson for all of us.
