Which tires should I purchase??
Old Mar 8, 2006 | 10:15 AM
bravastar1's Avatar
bravastar1
Default Which tires should I purchase??
My 2000 conv finally is getting new tires. The G/Y's made it to 19k. I dont really need run flats since I dont do any long road trips. What tires will work best for me and where will I get the best price?
Old Mar 8, 2006 | 10:56 AM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
http://forums.corvetteforum.com/showthread.php?t=1328634&forum_id=103
The Michelin Pilot Sports are the ones i chose while doing a search on tires...
Old Mar 8, 2006 | 11:09 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
KDW 2's. tirerack.
PSports are waaaay too expensive!
Old Mar 8, 2006 | 11:13 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Originally Posted by C5 KIDD
KDW 2's. tirerack.
I am running a set now, becuae of the great deal I got on the rears here from a forum member.. damn what was his name???? The PS do not hook worth a crap in a straight line even with 335 30s, and my old kuhmo ecsta 700s where way better in a straight line end turns. My next set of raod tires will be Kuhmo MXs. Good luck!
Dave
Old Mar 8, 2006 | 11:22 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
KDW 2's. tirerack.
Old Mar 8, 2006 | 11:28 AM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
I put on Kuhmo's last year and have been pleased with them.
Old Mar 8, 2006 | 11:30 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I think the best bang for the buck is the Firestone Firehawk Wide Ovals. All those that have them love them and they are priced right. The only problem I can see with them is they dont seem to be quiet as wide as the GY's. Because of that, I'm going with the GY GS-D3's which are about twice the price of the Firestones.
jeff
Old Mar 8, 2006 | 11:32 AM
johnandsarah002's Avatar
johnandsarah002
I have'nt had any problems with my Firestone WideOvals. All 4 installed in Z06 size for $770.00
Old Mar 8, 2006 | 11:35 AM
bravastar1's Avatar
bravastar1
Default Which Kumho??
Im new at this. Which Kumho tire are ya'll talking aobut? Thanks..
Old Mar 8, 2006 | 12:39 PM
C5 KIDD's Avatar
C5 KIDD
you have to decide what your looking for in a tire. kumho has the ASX series, and the MX series. both are good tires, and very well priced.
if you are looking for a everyday tire, with good performance without sacraficing tire life... then go with the ASX, or the BFG KDW 2's
MX's are a great tire. def. held the road very well. either tires i have found to actually "hook" from a dead stop, but i wouldnt expect them to. the MX's didnt really last that long though.
other "more expensive" tires will last longer, but cost sometimes more than twice the price!!
Old Mar 8, 2006 | 12:42 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Seems to me there has been some posts about success with Toyo's. I run those on my BMW and have had good success. Good tire - reasonable price. Do a search and you might be able to find the posts.
Old Mar 8, 2006 | 12:57 PM
The Goodyear GS-D3 is a good choice, as is the Firestone Wide Ovals. Firestones will be a little cheaper.
Old Mar 8, 2006 | 04:44 PM
WKMCD's Avatar
WKMCD
Originally Posted by chiefDave
: My next set of raod tires will be Kuhmo MXs. Good luck!
Dave
I just this minute came from prematurely removing a set of Kuhmo MX's. They probably still had 1/2 the tread left. They were very good tires until the last engine and rear upgrades. At 470RWHP with 3.90's they just wouldn't hookup at all. I replaced them with a set of BFG KDW 2's. We'll see how these work. 265x35x18 and 295x35x18
I've heard good things about them from people I trust.
Old Mar 8, 2006 | 10:41 PM
D_BlueVette's Avatar
D_BlueVette
I've had these Nitto NT 555 Extremes on for about 6months now and I'm very pleased so far.
http://www.discounttiredirect.com/di...d=004486&ar=45
Old Mar 8, 2006 | 10:46 PM
Dave68's Avatar
Dave68
...then check a recent edition of Car & Driver. Although they used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your C5. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 trad-wear grade. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
On a congratulatory note, the first place tire is made right here in the USA by an American tire company
Old Mar 9, 2006 | 06:59 AM
DeeGee's Avatar
DeeGee
(Best to worst):
This review should be a sticky given how often the question is asked
Old Mar 9, 2006 | 11:54 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I also have the Nitto 555 Extremes on the front and really like them and they are priced nicely
To Which tires should I purchase??
