Dumb Question
Old Mar 9, 2006 | 02:44 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Dumb Question
Ok this is probably a dumb question to ask but im gonna ask anyway. I have a 00 Camaro and I am thinking about selling it and gettin a C5. My question is how much lower does a C5 sit that a 00 Camaro. I also have a C3. both the c3 and camaro scrape on my driveway not bad though. the c3 just the fiberglass airdam scrapes a little and the camaro is the same way. So does a C5 sit lower or about the same as a Camaro. Sorry for such a dumb question but hey i fiqured it did not hurt to ask. thanks in advance
Old Mar 9, 2006 | 03:02 PM
DPG's Avatar
DPG
St. Jude Donor '06
if you are scraping now with the camaro, you WILL scrape with a c5. the good thing is that the only thing you are scraping is the air dam. Its black, you can barely see it, its on springs, so if you do scrape it has some give to it. The scraping sounds worse than it is. Also if you are hitting the bumper bars in front of the air dam, you can buy wheels for the bars to keep from crushing them under the vettes weight.
Old Mar 9, 2006 | 03:03 PM
HummelS's Avatar
HummelS
My lowered C5 scrapes a little on my driveway entrance. It's not a big deal with the C5, as the air dam has spring deflectors, and is cheap to replace.
jman1's Avatar
jman1
my C5 (not lowered) scraps on just about every thing bigger than an ant hill....
Old Mar 9, 2006 | 03:05 PM
Williams1999's Avatar
Williams1999
St. Jude Donor '06-'07
I had a 94' Camaro before my Vette and this car is without a doubt lower....
Old Mar 9, 2006 | 03:07 PM
Groucho's Avatar
Groucho
Default Yep...
I use mine as a snowplow...
Old Mar 9, 2006 | 03:16 PM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
my vette is lower than my 99 camaro (OK, its lowered all the way) but A stock height vette IS lower! no biggy just cant get any front bumper mods
GET THE VETTE
Old Mar 9, 2006 | 05:33 PM
My C5 (stock height) has about 4.5" of clearance in the front. Hope that helps.
Old Mar 9, 2006 | 05:39 PM
Oldvetter's Avatar
Oldvetter
I put wheels on my "scrape bars". Didn't need them after I put a concrete transition at bottom of drive. It helps to enter drive at an angle too. The C5 front airdam is spring loaded, it is also relatively cheap to replace ($35).
Good luck on getting a C5.
Old Mar 9, 2006 | 05:48 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Sounds like it's time to get the C5.
Old Mar 9, 2006 | 05:50 PM
istsme98's Avatar
istsme98
Old Mar 11, 2006 | 02:41 PM
Silver00V6Camaro
is that from the air dam or the bumper
Old Mar 11, 2006 | 03:42 PM
DeeGee's Avatar
DeeGee
Just measured the Camaro air dam and, at 4", it's exactly the same ground clearance as the Vert. Both scrape on my driveway.
The main risk of grounding is the rocker rails which are lower on the Vert. Overall the car sits about an inch all round lower than the Camaro.
Old Mar 11, 2006 | 06:23 PM
Silver00V6Camaro
thanks
Old Mar 11, 2006 | 09:57 PM
MilleniumVette's Avatar
MilleniumVette
2024 C5 of the Year Finalist - Unmodified
I own both, and haven't had a problem with the Vette that I didn't have with the Camaro. I know there will be instances, but I just haven't come across one yet... yet.
To Dumb Question
