Codes :-( ???
Old Mar 15, 2006 | 02:14 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Codes :-( ???
My windows will not go up, and the DIC is saying
1) "reduce engine speed" at a dead stop
2) check engine
3) tire pressure is low / which is not
4) Shocks inopperative
5) traction control inopperative
6) Service vehicle / only 5k on the meter
Please advise...... as to how I can reset this or is it a major problem?
Thanks,
Tony
Old Mar 15, 2006 | 02:17 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Sounds like things are going , hope it turns out to be a battery issue or something easy.
HummelS's Avatar
HummelS
Possible problem with the Body Control Module or other computer. Try resetting by pulling fuse 25 in the passenger footwell, wait 15 seconds or so, & then reinstall the fuse.
Old Mar 15, 2006 | 03:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Could be a battery going south - also could be some dirty/loose connections or grounds.
Here's an excellent post by Bill Curlee on this subject with pics....
http://forums.corvetteforum.com/show...ons&forum_id=1
Old Mar 15, 2006 | 07:28 PM
DeeGee's Avatar
DeeGee
Your profile doesn't say what year your Vette is.
If its an original AC Delco I'd change out the battery as a starter.
You can get some weird indications as it starts to go. Hopefully it didn't leak acid already but worth checking.
Old Mar 15, 2006 | 11:28 PM
MedChoice Tony
Default Thanks...
I will check the battery, and thanks for all the info..the codes went away and the window went up ....if it does it again..maybe I'll take her to the shop...it's a 2002
To Codes :-( ???
