DRL's
Old Mar 16, 2006 | 08:47 PM
slvr bulit's Avatar
slvr bulit
Default DRL's
Hey guy's just a quick ? What fuse shut's off the daytime running lamps? I love the look of my front black out's with the car off. Don't really like the running light's shinning through.
Old Mar 16, 2006 | 10:03 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
https://www.corvetteforum.com/techti...=273&TopicID=1
Old Mar 16, 2006 | 10:05 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
Under the hood...pull fuse #2...
...done.
I dont like them showing through either
Old Mar 16, 2006 | 11:37 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
...done.
Me neither.
Old Mar 16, 2006 | 11:59 PM
ALLEGRO's Avatar
ALLEGRO
OK here goes:
If you pull the #2 fuse you will LOSE some of the APPROACH features.
This is easy...I promise !
1. In the passenger footwell, lower the front carpet.
2. Remove the foot panel.
3. Locate the IPEC (Instument Panel Electrical Center) It looks like the fuse box next to the battery.
4. Remove the cover of the IPEC.
5. Turn it over and find the diagram of the components.
6. Locate relays 38 and 40. (38 controls the right DRL and 40 the left)
7. Pull each relay and carefully remove the cover.
8. Insert some type of insulator between the relay contacts (matchbook cover cardboard or the plastic from a coffee can lid works well) that you have cut to fit.
9. Replace relay cover, replace relay, replace IPEC cover, replace the footwell.
10. DONE!!
You will now have NO drl's and retain ALL of your APPROACH features. I have had mine this way for over three years and have had not a prob. Good luck and feel free to PM me with any question you might have.
Old Mar 17, 2006 | 12:18 AM
MrLeadFoot's Avatar
MrLeadFoot
Nice! Thanks for the instructions.
To DRL's
