[Z06] Valve noise
Old Aug 15, 2001 | 09:48 AM
abarth's Avatar
abarth
Default Valve noise
I drove a 2001 Z06 yesterday with less than 2000 miles. Seems to have a slight valve noise that you can here from drivers seat. Is this a problem? Our 99 did not seem to have this valve noise.
Old Aug 15, 2001 | 10:24 AM
Grendel's Avatar
Grendel
Default Re: Valve noise (abarth)
I have experienced the same noise with mine. I have a little over 5000 miles on it now, and either don't notice it anymore or it is gone.
Old Aug 15, 2001 | 11:09 AM
VettesRule's Avatar
VettesRule
My car has the same noise. I don't think it is a problem.
Old Aug 15, 2001 | 01:29 PM
jefffxdwg's Avatar
jefffxdwg
Default Re: Valve noise (VettesRule)
The fule injectors make noise and if you mechanicly over rev. the engine you will bend pushrods and they will make noise.
Jeff
Old Aug 15, 2001 | 03:12 PM
MyC5's Avatar
MyC5
Default Re: Valve noise (jefffxdwg)
Probably fuel injectors if:
you hear it until the fuel pumps quiets off or it goes away with slight increase in RPM.
Old Aug 15, 2001 | 03:36 PM
Grendel's Avatar
Grendel
I have experienced bent valves. I over reved my 1999 Firehawk by down shifting to second instead of fourth at 90 mph and bent the valves. The sound was a lot more noticable than the noise from the Z06. The first time I noticed the Z06 making the noise, I have to admit I was scared the valves were damaged, the noise is very similar. The only things that made me believe the Z06 was ok, is the fact I know I never had over reved it and there were several posts on this formum from other owners with the same concern that believe it is a natuaral behaviour of the Z06.
Old Aug 15, 2001 | 03:39 PM
zeeman's Avatar
zeeman
Valve noise is NORMAL!!! :cool:
Old Aug 16, 2001 | 09:24 PM
Power Shifter's Avatar
Power Shifter
I have goten to the point that I can now hear when the car is 1/2qt down by the valve train sound increace. The cam profil is more radical in the ZO6 so there is more noise. I will trade noise for power any time with in reason. Ric
Old Aug 17, 2001 | 03:08 PM
Lambinator's Avatar
Lambinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In V AutoX Winner
Default Re: Valve noise (Power Shifter)
Ah HA! I just started noticing this noise myself last night for the first time and was really starting to sweat it. Glad to hear that it "appears" to be normal. The car just hit 500 miles and I have not overrevved it.
Old Aug 17, 2001 | 06:02 PM
MitchAlsup's Avatar
MitchAlsup
Default Re: Valve noise (Lambinator)
I attributed this noise to the roller tappets and roller rockers. Together they make a "sewing machine" clatter which gives ME the impression that all is ok with the world/engine--freedom from friction is accompined with noise from that freedom. With zillions of little roller pieces moving constatly, is there any wonder that some sound eminates from all of them moving in concert?
Relax, understand and enjoy!
Old Aug 17, 2001 | 06:18 PM
johnob's Avatar
johnob
4th Gear
Are you sure it was valve noise? The Z06 trans makes a distinctive rattling.
I have a little valve noise, too, and the dealer says it is normal.
Old Aug 18, 2001 | 12:25 AM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
I do not have it with my Z06 - but I did have it with my 2000 Coupe. I heard an engine flutter under normal acceleration that drove me nuts. There was no extra noise at idle or normal cruise, but the flutter was really grinding. In fact - thats why I bought a new car! I think some LS1/6 engines have the noise and some don't.
To Valve noise
