bose system?
Old Mar 21, 2006 | 02:10 AM
whats_the_retail's Avatar
whats_the_retail
5th Gear
Default bose system?
how can i keep the bose system while adding a aftermarket headunit?
Old Mar 21, 2006 | 06:29 AM
ronwc's Avatar
ronwc
Most guys use the soundgate adaptor -
Old Mar 21, 2006 | 07:09 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
As indicated either the soundgate adapter or the Pac-audio adapter is the way that most go to integrate an aftermarket H/U with the Bose speakers.
Have a look here at this sticky post in the audio section
http://forums.corvetteforum.com/show...59&forum_id=20
It will answer a ton of questions you may have as you go along.
Also the folks in the audio section in general are equipped to answer these questions better for you.
Paul
Old Mar 21, 2006 | 08:39 AM
DeeGee's Avatar
DeeGee
Heres the item you need:
http://www.soundgate.com/index.php?r...&usereferrer=1
Old Mar 23, 2006 | 01:25 AM
whats_the_retail
5th Gear
i ordered the soundgate adapter. thanks
To bose system?
