Worth the while?
Old Mar 27, 2006 | 08:24 AM
TAGVETTE's Avatar
TAGVETTE
Default Worth the while?
I've got just over 60K on my 02 MN6. I was thinking of doing some work to it (routine maintenance) when it warms a bit.
Oil Change
Fuel Filter Change (OEM still in car)
New Plugs/Wires/Ignition Coil
Would it be worth it?
Old Mar 27, 2006 | 08:28 AM
DeeGee's Avatar
DeeGee
If youre happy doing that type of work it'll save mega $ at the Stealers.
The Corvette tax is still alive and thriving
Old Mar 27, 2006 | 09:29 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Oil / oil filter change, fuel filter change, plugs... sure.
Plug wires... not really.
Have fun.
Old Mar 27, 2006 | 11:18 AM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
I would inspect the plug wires, mine were crumbling and cracking at just 30K.
Old Mar 27, 2006 | 11:28 AM
Kanmer's Avatar
Kanmer
Its always worth it to do general preventative maintenance to your car. There is a plus side to this. You will have bonding time with your car. You might really want to rethink, or at least research, the coil thoughts. I always love working on my car. Its like therapy for me. When I get I ANd shicne and wrench. Then its
Bob
Old Mar 27, 2006 | 03:45 PM
edensknight's Avatar
edensknight
Old Mar 27, 2006 | 05:44 PM
Oil and filter change would be a good idea. As for the plugs, wires, etc - just check them over and see what they look like. If needed, you can replace them.
Old Mar 27, 2006 | 06:00 PM
ebubman's Avatar
ebubman
your list seems pretty reasonable & doable. may want to check thru the o.m. for other 60k items to check/top off/et cetera. bub
Old Mar 28, 2006 | 11:26 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
Oil Change
Hopefully that's not the FIRST oil change.
To Worth the while?
