Quick steering wheel question
Old Mar 27, 2006 | 04:46 PM
mkiv808's Avatar
mkiv808
Default Quick steering wheel question
What do I need to remove the airbag? There's an annoying squeak on my steering wheel that's only getting worse. Something's gotta be loose under there.
Thanks in advance!
Old Mar 27, 2006 | 05:40 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I have heard that hitting a tree at 25 mph will do the trick
Old Mar 27, 2006 | 08:08 PM
mkiv808's Avatar
mkiv808
C'mon, someone has to know. It's gotta be two torx screws or something.
Old Mar 27, 2006 | 08:37 PM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
https://www.corvetteforum.com/techti...D=35&TopicID=1
This should help a little.....
Old Mar 28, 2006 | 02:34 AM
mkiv808's Avatar
mkiv808
I'm not sure, but I don't think it's that. It doesn't happen when I turn the wheel. It happens on bumps or when I hit the steering wheel. And when I push the steering wheel in, it stops. That makes me think it's a loose bolt.
Old Mar 28, 2006 | 03:15 AM
WWK888's Avatar
WWK888
Although this may not answer your question, you may want to check this out anyway.
http://www.vetteessentials.com/instr...l/stwheel.html
Old Mar 28, 2006 | 04:16 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
That's one job that if you have to ask you shouldn't be doing!
Old Mar 28, 2006 | 09:09 AM
DeeGee's Avatar
DeeGee
Plenty of scope for "**** up" for the uninformed.
Old Mar 30, 2006 | 03:55 PM
mkiv808's Avatar
mkiv808
How the heck could the airbag deploy? I wouldn't even have to disconnect it. I've taken out a few steering wheel/airbags in other cars and can't see how that's remotely possible.
To Quick steering wheel question
