What's faster???
Old Mar 28, 2006 | 02:38 PM
itsmeek's Avatar
itsmeek
http://videos.streetfire.net/categor...A25F714744.htm
note that the z06 is not even the 405 hp one, it's an '01. both cars are stock.
Old Mar 28, 2006 | 03:13 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
That proves it... Plus that Z is an 01 the 02-04 Z's are even faster with 405-hp. I'm about to cash in... Thanks!
Old Mar 28, 2006 | 03:47 PM
ORANGEBROTHERS
So I guess we can assume a stock 350hp - C5 six speed with an aftermarket exhaust and intake should be able to take the C6 as well.
Old Mar 28, 2006 | 03:53 PM
Nulltime's Avatar
Nulltime
If I am not mistaken the official diffrence is half a second around an oval track.
Old Mar 28, 2006 | 04:08 PM
ZO6vettepilot's Avatar
ZO6vettepilot
Too many possible variables. The C6 with Z51 has the same gearing as the Z06 MN12, the manual C5 has the MN6 gearing. A C6 auto with the performance gearing could be quicker because there's no thinking about the launch or the shift. The C6 weighs a little less than the C5 of the same body styles, but still not as light as the C5 Z06. So it would be very close providing the C6 was essentially stock. The LS2 power comes on a little sooner than the LS1 so that could help if it got out front first, playing catchup is always difficult.
Old Mar 28, 2006 | 04:12 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Driver skill being equal, no. An aftermarket cat-back exhaust and intake only(without any tuning I might add) are not enough to make up the difference in the 50 RWHP advantage the C6 has over a C5(non Z). Assuming both cars are MN6 or Autos...even still 50RWHP is quite a difference.
Old Mar 28, 2006 | 04:16 PM
Jim2003's Avatar
Jim2003
I believe that is has been written about in mag's that the C5 Z06 will beat a C6. As everyone has said driver difference could and will make a difference. With professional drivers, the C5 Z06 will always win.
Old Mar 28, 2006 | 04:23 PM
LF97C5Vette's Avatar
LF97C5Vette
So whats the RWHP difference between a C5Z and a Non Z C5?
A stab in the dark from a newbie =
Stock C5 350hp 315 to the wheels.
Stock C5Z 385hp, 350 to the wheels.
So if you toss on a couple mods to get your C5 up to the same RWHP as an Early C5Z (~350ish?), then you're runnin with or possibly beating the C6 non Zs?
Old Mar 28, 2006 | 04:37 PM
vettesmith02's Avatar
vettesmith02
How does the race turn out on the C-6 forum?
ORANGEBROTHERS
Old Mar 28, 2006 | 05:20 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Stock C5 350hp if it is a 6 speed, it's probably on average about 305-310 RWHP..maybe a few factory freaks at 315... an A4 C5 stock is about 290-300 RWHP..more loss of RWHP due to A4 trans
Stock 2001 Z06 @ 385 HP is probably about 330-345 RWHP..give or take again rough estimate depending on miles on the car etc...
Stock 2002+ Z06 is 405 flywheel, and about 350-355 RWHP
The intake and exhaust mods are not going to give you that much HP without tuning... Headers will give you more power and you will notice a difference, but again to get full advantage out of the HP the car needs to be tuned... you can probably gain 10HP from an intake with out tune,, but that is 10HP at the flywheels..so almost nothing to the wheels.
The real gain is when you add headers, cam and a tune...then your talking real power that will make a difference vs a stock C5 Z or C6 stock.
Old Mar 28, 2006 | 05:35 PM
Casem1's Avatar
Casem1
Don't forget weight.
Old Mar 28, 2006 | 05:50 PM
  #33
LF97C5Vette
Curb Weight - Manual (lb.) C6 - 3179lbs || C5Z - 3115lbs || C5 - 3229lbs
The 97 Coupe is 50lbs heavier than the C6
The 01 C5Z is 64lbs lighter than the C6 and 114lbs lighter than the C5.
The 114lbs difference between the C5Z and the C5 would have to be considered when modding the C5 to the same RWHP as the C5Z
Source:
http://autos.msn.com/research/compar...=t92758&v=t151
Old Mar 28, 2006 | 06:04 PM
  #34
army2000's Avatar
army2000
St. Jude Donor '11
The '04 CE ZO6 is the fastest of the C5 generation. It should put down a stock C6 with no problems. That being said, the C5 Z vs the C6 will probably come down to the drivers, but my money's on the C5.
Old Mar 28, 2006 | 06:16 PM
  #35
David426's Avatar
David426
Your numbers are right on 290-300 for an automatic and 305 310 for 6 speed
Old Mar 28, 2006 | 06:33 PM
  #36
LF97C5Vette
So a base C5 would have to make up a 40hp and 100lbs defficite to compete with a base C6... not too terrible... a couple mods and some good driving and you'd be smoking C6's probably...
Old Mar 28, 2006 | 06:36 PM
  #37
StealthZ06's Avatar
StealthZ06
Don't forget the C5z06 has more agressive gearing. The regular C5 will need more hp than a C5 Z06 to achieve the same times due to the weight and gearing difference.
Originally Posted by CorvetteForum
M12 6-Speed Manual
This transmission is unique to the Z06, and is the only transmission available for that model. It is not available on Corvette coupes or convertibles. It has more aggressive gearing to increase torque multiplication in most forward gears, allowing for more rapid acceleration and more usable torque at higher speeds.
Gear Ratios
LS1/MM6 LS6/M12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
To What's faster???
Old Mar 28, 2006 | 06:38 PM
  #38
ebubman's Avatar
ebubman
Originally Posted by HERK
make sure you go to a track.the c6 by a lenth.
agree, particularly on the track part of the equation. bub
Old Mar 28, 2006 | 06:51 PM
  #39
LF97C5Vette
Good point. Does the Base C6 have that trans too?
So it looks like you'd probably need to add somewhere around 60rwhp or more to your base C5 to keep up with C6s...
Old Mar 28, 2006 | 08:02 PM
  #40
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Trying to settle a bet… A friend is buying a new C6 coupe and says it will dust the old ZO6 no problem. I’m calling him out on it.
Honestly, I think it will depend on the driver, but I think the ZO6 has an edge.
