[Z06] Shorty antenna
Old Mar 30, 2006 | 11:19 PM
heavymetals's Avatar
heavymetals
Install the electric antenna option.
Best of both worlds.
Old Mar 31, 2006 | 12:15 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Originally Posted by Blooty
Since my car is going for a little check up...I might as well look into some easy mods. Is the shorty antenna something someone like me (a grrrl with no power tools) could put on easily? Third or fourth dumb question for youse keeping track
Hi Blooty -
I cut mine down to 9".
I used a rag and some vice grips to pull the **** off of the mast -
I cut the mast to 9", and then I used a dremel to machine the mast tip down so it would fit into the hole in the ball (tight interference fit).
I also used a dab of silicone in the hole for additional assuranceit would not come off.
Then, just paint it black again and you are good to go.
No problems with reception that I can tell - radio comes in good, and the antenna looks cool!
I bought a stock replacement mast for around $10 to have just in case I want the "state police whip look" again...
best regards -
mqqn
Old Mar 31, 2006 | 09:17 AM
SMR 67's Avatar
SMR 67
I've seen this from Mid America and read the installation instructions. Has anyone installed one of these and if so, is it a PITA or pretty smooth going?
Old Mar 31, 2006 | 08:41 PM
rudyarias's Avatar
rudyarias
Originally Posted by lt1rx798
is the reception any better or worse?
Worse! I can only get reception if I'm in the city, SOL when in the suburbs
Old Apr 1, 2006 | 07:15 PM
Rdavis's Avatar
Rdavis
Didn't see this post.
I just posted how I made my own "midlegnth" antenna
