Plugging Tires
Old Apr 5, 2006 | 09:35 PM
bekdad's Avatar
bekdad
Default Plugging Tires
About a mile from work at 6 AM today, I took a quarter inch by one inch wood bolt in the driver's side front tire. Thump, thump, thump, all the way to the shipyard, but the air held.
Came out during lunch to fix this problem - air still holding in the tire. Turned the front wheel all the way to the left, and positioned it to get a clear shot at the bolt. Jacked it up just enough to get the tire clear of the ground. Had the bolt out in less than a minute, and the plug inserted five minutes later. Only "hard" part was putting the air back in the tire - took over 10 minutes with my cheap compressor.
This wasn't my Vette, but it just as easily could have been. I have three take-aways:
1. Sometimes it's easier/quicker to plug a flat, than putting on the spare.
2. We never hesitate to drive our "other cars" everywhere, without runflats, but many of us would never consider anything but runflats on our Vettes.
3. Need a better compressor.
Yes, there are situations where the runflats are nice to have, but not very often.
Old Apr 5, 2006 | 10:17 PM
rws.1's Avatar
rws.1
To plug or not to plug that is the question...
I'm a plug man myself.
Old Apr 5, 2006 | 11:24 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i've plugged it a few times.
Old Apr 5, 2006 | 11:35 PM
LS9's Avatar
LS9
plugs work fine
Old Apr 5, 2006 | 11:40 PM
water's Avatar
water
Default plugs
I like plugs myself on a everyday car or truck but on a vette I would like a patch. But if I was to have a flat I would do the plug also because when the tire shop gets the tire off the rim they will haved done scratch it up.
Old Apr 5, 2006 | 11:44 PM
turbo1k's Avatar
turbo1k
They make a patch with a plug built in, Town Fair has them and they will give you one for free.
Old Apr 6, 2006 | 12:20 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
The big difference between a C5 and the "other" car...the other car has a spare.
Old Apr 6, 2006 | 09:37 AM
John's '07's Avatar
John's '07
From: I don't deserve this car, but I have arthritis and I don't deserve that either. Bay Point, FL
Old Apr 6, 2006 | 10:02 AM
AU N EGL's Avatar
AU N EGL
23000 miles on non run flats and NEVER HAD a flat. If I did, it would be call AAA. IMHO no need to carry all that extra weight. Just a cell phone.
When the wifes 04 vette needs new tires, no run flats, Mich PS/2s will go on.
Old Apr 6, 2006 | 11:51 AM
Old Man in a C's Avatar
Old Man in a C
Originally Posted by LS9
plugs work fine
What he said
Old Apr 6, 2006 | 11:54 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Bingo
Old Apr 6, 2006 | 03:04 PM
Red3644's Avatar
Red3644
Default might as well ask here
I have no experience with runflat issues. I just noticed a small nail in one of runflats. It looks like a small finishing nail, the head is less than 1/8" wide and I don't know how long. There's no air loss. It's in the center rib. It looks too small to get a plug in. What do you do in a case like that.
Old Apr 6, 2006 | 03:59 PM
bozo4onion's Avatar
bozo4onion
1. I took a staple with two small holes too close together for two plugs.
2. Goodyear does not recommend repairing ANY runflat.
3. They cost $360, Dayum.
Old Apr 6, 2006 | 04:02 PM
HummelS's Avatar
HummelS
Goodyear does not recommend PLUGGING a runflat. The correct repair is a patch from the inside. This will maintain the speed rating of the tire.
Old Apr 6, 2006 | 06:05 PM
LoneStarFRC's Avatar
LoneStarFRC
Best way to go on any tire if possible. (Goodyear or not)
Old Apr 6, 2006 | 11:21 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Had two plugs in the same EMT, drove on them for over 40,000 miles with no issue..even down to 2/32
Old Apr 6, 2006 | 11:29 PM
Oldvetter's Avatar
Oldvetter
I plugged two Goodyear Runflats (one front, one rear), ran on them for over 40,000 miles also with no problems.
The issues are 1) Water getting in from outside tire and causing steel belt to rust and fail, this is why they want a plug, and 2) air getting inside belts from inside the tire causing belt seperation and failure, this is why then want a patch on the inside of the tire.
To Plugging Tires
