Drivers door memory switch
Old Apr 8, 2006 | 11:15 AM
rehirsch8's Avatar
rehirsch8
Default Drivers door memory switch
I remember a few threads last year were people swapped out their non-memory window switch panel for the panel with the memory buttons on the driver side door. Once installed the drivers seat, mirrors, and steering column if equiped remembered the last setting even though the car did not originally have the memory seat option.
I got a hold of a memory seat switch and installed it in my '04 coupe. The memory switch does not work but all the other buttons function normally. Does anyone know if there is something else required? Is the wiring harness different or the programming in the BCM?
Thanks!!
