first mod? TC or intake?
Old Apr 20, 2006 | 01:24 PM
vettestream's Avatar
vettestream
Default first mod? TC or intake?
Hey guys,
A while back I had posted about the best type of perf. mods to get for less than 1K; anyway, now that its spring I am ready to do my first mod, however I am torn between the Varaam or a TC. Of these two, which do you think will provide the most noticeable increase in performance/ fun factor?? (Especially in the low end, 0-60 etc...).
Also what type of stall do you recommend I get if I am only going to do intake/exhaust and a tune? And where do you recommend buying it from/best price?
BTW its 2001 a4 w/ 3.15
Thanks in advance
Old Apr 20, 2006 | 01:31 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Intake is by far the best bang for the buck - bar none.
After that - gears.
Old Apr 20, 2006 | 01:33 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
Only help i can offer if you are going to go to a supercharger or turbo hold off and save your money. I went with a Hurricane intake. Wish i had waited only because of the added expense i incurred later when i went turbo.
Old Apr 20, 2006 | 01:48 PM
vettestream
thanks, yea I dont plan on going the Turbo/ SC route, just basic bolt ons etc..
Old Apr 20, 2006 | 02:28 PM
WKMCD's Avatar
WKMCD
After that - gears.
Old Apr 20, 2006 | 02:36 PM
edensknight's Avatar
edensknight
After that - gears.
Old Apr 20, 2006 | 03:25 PM
9secondflat's Avatar
9secondflat
no question, a torque converter will cut .5 seconds off your 0-60 time if, and i mean if you dont blow the tires off the pavement.
Old Apr 20, 2006 | 03:29 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
However a new one and the cost of install will most likely exceed the $1000.00 he mentioned in his first post.
Old Apr 20, 2006 | 06:11 PM
PUREFUN's Avatar
PUREFUN
Then i would go gears and then intake. Check the parts forum should be able to get everything there for half the price of new
To first mod? TC or intake?
