C-5-Center Console Problem
Old May 7, 2006 | 10:38 AM
LAHeat's Avatar
LAHeat
LA Heat
Default C-5-Center Console Problem
Just bought a '04- C-5 (Z06) and noticed that the center console (storage area) will not rise all the way up (even w/ the emergency brake off or down). It only goes up a few inches. I am afraid to "force" it up all the way. Surely this was not designed this way or was it????
Whats up w/ this? Is it common or is it a defect that can be corrected? It is certainly a pain!
Any comments or suggestions?
Old May 7, 2006 | 10:54 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
It is double hinged sortaof , give it a good yank !
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
It's a double knuckle hinge. It's so it clears the e brake handle when it's up. Pull it towards you as you lift.
Old May 7, 2006 | 10:57 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
BATM4N's Avatar
BATM4N
I freaked out too 4 months ago with same exact problem. Just raise it up like your life depended on it and she'll come right up. It's doubled hinged.
Old May 7, 2006 | 11:01 AM
RJS91RGTP's Avatar
RJS91RGTP
Default C-5 Console Problem
Good morning to all from suburban Chicago. A beautiful day here as was yesterday and the top will be off for Sunday cruising. This console problem is easy to fix. As someone stated, there is a double hinge on this thing and mine was tough to open as well. Just lubricate the hinge with WD-40 or some other lubricant and you will be able to lift it with one finger. The difference will amaze you. Try it. Enjoy the rest of the weekend.
RJ
Old May 7, 2006 | 11:49 AM
JohnsC5's Avatar
JohnsC5
RJ
Old May 7, 2006 | 11:50 AM
army2000's Avatar
army2000
St. Jude Donor '11
With pics.
http://www.c5forum.com/diy/console_hinge.php
Old May 7, 2006 | 11:55 AM
1 Nasty Z's Avatar
1 Nasty Z
Originally Posted by army2000
Excellent tech tip here. Never thought the oiling of a hinge could be so complicated.
Old May 7, 2006 | 01:25 PM
Old Man in a C's Avatar
Old Man in a C
I know the problem. True, it's a double link hinge, but knowing that won't solve the problem. One drop of light oil on the hinge points will make a world of difference. Seems too simple, but it took another forum member to spell it out for me. Try it.
Old May 9, 2006 | 07:25 PM
LAHeat's Avatar
LAHeat
LA Heat
OUTSTANDING -- Thanks to all who replied Thanks, it worked!!!!!!!!!
Old May 9, 2006 | 07:43 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
From simple fixes to complete engine install - this Forum has it all.
I love this Forum
Old May 9, 2006 | 08:19 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
I love this Forum
and Amen to that Stephen.
Old May 9, 2006 | 10:07 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
...this should be included on a sheet of all the things a newbie C5 owner needs to know now...
...hmmmm
Old May 9, 2006 | 10:41 PM
army2000's Avatar
army2000
St. Jude Donor '11
I love this Forum
How about; "How to keep the overweight English dude from sucking up bandwidth and taking up server space"...has anyone fixed that one yet...
Old May 10, 2006 | 01:13 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Where did you get the tool you are using to put the oil on the hinge?Thanks charlene
Old May 10, 2006 | 01:21 AM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
I love this Forum
it si a great place!
To C-5-Center Console Problem
Old May 10, 2006 | 01:36 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
This is sooooo cool. All this time, I thought the cover only opened up partially. I'm going to go oil mine tomorrow!
Old May 10, 2006 | 01:40 AM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
That's the way.
Old May 10, 2006 | 06:45 AM
You do have to pull up with some force to get it past the first opening position. It should go up to a 90 degree position compared to the rest of the console.
