"window stops"
Old May 9, 2006 | 08:57 PM
glennxx1's Avatar
glennxx1
Default "window stops"
the red reflectors off the door panel and adjust the bolts, if my regulator was binding would that fix it.
Old May 10, 2006 | 05:22 PM
Hammie's Avatar
Hammie
All that does is tip your window in or out, man. I seriously doubt that would fix a regulator binding issue, but you could try.
Old May 10, 2006 | 05:59 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The jam nut behind the reflector is to adjust the window tip-in and out. One rotation will "tip" the top of the window in towards the car or out from the car .040"
Paul
To "window stops"
