How does your C5 accelerate?
Old May 12, 2006 | 01:37 PM
Frozenfire's Avatar
Frozenfire
Originally Posted by Billy182
Just curious, what did the dealer tune consist of? Just plugs and wires? De-carbon top clean? Fuel injector clean? Fuel filter?
It sounds like something is amiss with the engine performance diagnosis. Did a competent tech take it for a test drive?
Good points, all. There's a place just south of here called Corvette 911 or something like that down around Columbus, NJ. They seem to come highly recommended, so I'll give them a try. Thanks CF!
Old May 12, 2006 | 01:39 PM
WKMCD's Avatar
WKMCD
Mine runs clean and strong up to 3k and then starts coming on really strong until 5k when all hell breaks loose up to 6600RM.
Wouldn't have it any other way.
Old May 12, 2006 | 01:44 PM
Frozenfire's Avatar
Frozenfire
My accountant has a ZR1 and my mortgage broker has a '65. I'll give them a test ride and see what they think. They're both responsible for giving me the impetus to buy the car. Nice friends to have around.
Old May 12, 2006 | 01:47 PM
Cole's Avatar
Cole
Originally Posted by Frozenfire
Good morning all. I have a question about how a 2000 (vert) should respond when you get on it. Should there be a smooth, uninterrupted acceleration, or does the C5 have some quirks? Mine came with Magna Flows and a K&N air filter and was recently given a tune up by a dealer (I know some of you hate dealers, but I bought a GM extended warranty.)
The reason I ask is because when I go full throttle in 1st or especially 2nd, I can feel a sort of "stepped" acceleration rather than a linear one. What're your thoughts?
Turn off Traction control. Run it in competitive driving mode which cab save you in a skid but shuts off the TC. When I upgrade my intake, I found the TC inhibited acceleration.
Old May 12, 2006 | 02:12 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I don't suppose anyone gives a rat's butt what I think about this, but what the hell, here goes nothin'...
On my A4 '04 coupe, when I "mash it" from a standstill (with the TC off), it DOES kind of accelerate slower than when it finally reaches about 3200 RPM, where THEN it begins to accelerate much faster.
FAR from being "linear", in my opinion.
Now, of course, those with 3.42 and 3.73 gears will not have as much, if any at all, of this low RPM lag, and will spout off that THEIR ride is completely linear in acceleration.
I've found that stock or near stock vettes with 2.73 and 3.15 gears are no where near "linear" in their acceleration curve. And all the "tuning" in the world isn't going to alleviate the "problem".
But then again, what the hell do I know, right?
Old May 12, 2006 | 02:38 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Mine runs like a cat with scalded *********.
Old May 12, 2006 | 02:45 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Maybe you can check out the NE Events section and meet up with some CF folks and go for a ride in their Vette and/or have them ride in your ride and see if it seems O.K.
Old May 12, 2006 | 03:19 PM
Frank55's Avatar
Frank55
What you are calling a stepped acceleration sounds like something called "hesitation." Suggest you have a good mechanic look at it.
Old May 12, 2006 | 04:05 PM
Frozenfire's Avatar
Frozenfire
I'll give it a try this afternoon.
Old May 12, 2006 | 04:26 PM
KemahC5's Avatar
KemahC5
Found this to be true with my stock A4 with 2.73 gears.
Old May 12, 2006 | 04:30 PM
Dark-Knight's Avatar
Dark-Knight
Mine runs hard and true, no problems.
Old May 12, 2006 | 05:18 PM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
That's not exactly true. The PCM program can be modified (especially in the A4) to alter shift-points, down-shiftng, torque-management, fuel to air ratio, increased HP & TQ (in '01 & up there is ~15-20 RW available), etc. Remember, GM programs the car for the average driver, not us Ron Fellows wannabees!
You can send out a PCM card & have it re-programmed.
Old May 12, 2006 | 05:58 PM
  #33
Z28TOZO6's Avatar
Z28TOZO6
Ny Z still occasionally scares me it is so responsive. I do believe I shat myself!
Old May 12, 2006 | 06:02 PM
  #34
MagikDraggin
Cruise-In V Veteran
I realize this ain't no "debate forum" and I mean no disrespect to you, but there is no way messing with shift points and A/F ratios etc is going to make up for the simple absense of horse-power in the 0-1500/2500 rpm range.
Turning off the TM might allow a better take off to some degree, but not to the extent that it makes the acceleration linear and not feel that typical surge when the engine finally gets up in the part of the power curve where it actually starts making some serious horsepower.
It is people with head and cam mods, SC's, lower (numerical) gears, high stall converters, that are telling this fellow that all he needs is a "tune" and everything will be "better".
It simply won't be any "better" as far as the non-linear feel (lag) of the acceleration goes...but a tune will provide a nominal overall increase in power output....[/i]once[/i] the Vette gets up some speed and RPM's.
Just my opinion, of course.
Old May 12, 2006 | 06:58 PM
  #35
Sully C5's Avatar
Sully C5
Since my car was the first 2001 that received a PCM re-program, my Tuner spent two weeks & a series of re-programs by both Ed Wright, & Jim Hall...there are factors in the PCM program that can effect the Timing, HP & TQ, the fuel/air ratio.
But you are entitled to youir opinion. As I am entitled to mine based on my personal experiences & dozens upon dozens of dynos and seeing the impact on the TQ curve, which is what provides your acceleration.
So at best, let's say we agree to disagree!
Old May 12, 2006 | 08:46 PM
  #36
ebubman's Avatar
ebubman
stock a4 w/ performance axle ratio. runs incredibly strong right up to red-line shift! consistently strong as hell! bub
Old May 12, 2006 | 09:22 PM
  #37
JTJ's Avatar
JTJ
St. Jude Donor '08-'09
Linear for me and loving it
To How does your C5 accelerate?
Old May 12, 2006 | 10:19 PM
  #38
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Actually, you raise a very valid point. There are two other factors that can come into play... especially with automatics.
1. Torque Management (different from Traction Control) can cause a very noticeable "stumble" if you whomp on it from a standstill or slow roll.
2. The stock torque converter can make accelleration from the bottom of 2nd painfully slow if you are too fast for the transmission to downshift but too slow to have the revs up. You have to wait for the rpm to climb into the power band.
I no longer have these issues... I have different ones now.
Old May 12, 2006 | 10:25 PM
  #39
LF97C5Vette's Avatar
LF97C5Vette
What i mean by linear, is that the horsepower increases at a steady rate with RPMs. So that when accelerating it gets more and more powerful steadily. Starting from relatively weak, and ending at ridiculous. I don't feel any real jumps in power, just a quick and steady increase. Unlike a honda hitting VTEC at 5800RPMs, you notice a HUGE jump in power within a very short RPM range.
Assuming your car is properly "Tuned" you should see a fairly linear increase in power w/o any large jumps, gaps or spikes. Thats what i mean by linear... I wasn't trying to imply that the car feels as powerful at 1500rpms as it does at 5500rpms... lol
This is a large Jump!
This is a linear increase
Dan
Old May 13, 2006 | 01:11 AM
  #40
MagikDraggin
Cruise-In V Veteran
Originally Posted by LF97C5Vette
What i mean by linear, is that the horsepower increases at a steady rate with RPMs. So that when accelerating it gets more and more powerful steadily. Starting from relatively weak, and ending at ridiculous. I don't feel any real jumps in power, just a quick and steady increase. Unlike a honda hitting VTEC at 5800RPMs, you notice a HUGE jump in power within a very short RPM range.Dan
I understood exactly what you were saying, and at the expense of beating this horse any further, The A4 C5's I have driven are far from "linear" in the straight-line acceleration. There is most definitely a dramatic increase in the power level once the R's get up into the mid 3000 range. So much so that it almost feels like a 75 shot of nitrous just kicked in.
Funny think though, this does NOT show up on the dyno graphs......for all practical purposes, it LOOKS "linear".
However, since having had the cam change, and the Yank SS3200 TC put in, there is no such surge of power like when it was stock. This thing just flat out lifts off and flies when the go-pedal is slammed to the floor...even with the Mickey Mouse 2.73 gears.
For what it's worth.
