Flush taillights ?
Old May 20, 2006 | 02:12 PM
ace1's Avatar
ace1
Default Flush taillights ?
Has any body installed the flush mount tail light kit? They look cheap and flimsey are they worth the $33.00 or are they junk how about some input
Old May 20, 2006 | 02:18 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Don't buy the kit, just do it yourself
Flush Mounted Tail Lights
(6) 1" L X 1/2 W X .194" Hole Size Nylon Spacers
(6) 1/4" L X 1/2" W X .194 Hole Size Nylon Spacers
(8) #8 x 2" Zinc Pan Head Screws
(1) Frost King Rubber Foam Weatherseal 3/8" W X 5/16" Thick x 10' Long (Adheasive backed)(I got the black weather stripping)
Simply unscrew tail lights, clean, put weather stripping around the tail light (where the red casing meets the black casing of the light) insert new screws and spacers on back side, screw back into mounting hole.
-The two center lights get one 1" spacer on each screw.
-The outside lights get three 1/4" spacers on each of the outer most
screw
-The inner screw on the outside most lights get one 1" spacer.
-Fit so the weather stripping looks good and screw them back in!
1" spacers $4.77
1/4 Spacers $3.42
Weather stripping $3.98
Pan head screws $.98
Peace
Willfulone
__________________
..................Click for
Old May 20, 2006 | 02:20 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
I got lazy and bought mine. I love them.
Old May 20, 2006 | 02:21 PM
Lowcash's Avatar
Lowcash
Old May 20, 2006 | 02:23 PM
ace1's Avatar
ace1
Thanks,yours tail lights look great, Ace
Old May 20, 2006 | 03:40 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I was lazy too. I bought my kit from West Coast Corvettes. The nice thing about this mod is if you decide later to change it back, you can.
Old May 20, 2006 | 05:16 PM
showvette50th's Avatar
showvette50th
kit works well
Old May 20, 2006 | 05:29 PM
poolhustler's Avatar
poolhustler
I guess I'm lazy too!! I bought the kit also, but modified it becuase I wanted one side on each light out a little farther. Turned out good. Here's some pics....
Good luck with your install!!'
Russ...
Old May 21, 2006 | 11:55 AM
ace1's Avatar
ace1
ttt
Old May 21, 2006 | 12:21 PM
jrose7004's Avatar
jrose7004
It would be a great mod!
Old May 21, 2006 | 12:38 PM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
I can't remember if I got my kit from LAPD or CoH but it works well and was easy to install.
Old May 21, 2006 | 01:28 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Flush Kit
I have to agree with willfulone I made my kit for about 11.00, you cn get all parts from Lowes.
Old May 21, 2006 | 05:19 PM
ace1's Avatar
ace1
ttt
Old May 21, 2006 | 07:35 PM
YO-EL's Avatar
YO-EL
Old May 21, 2006 | 08:27 PM
J Z06's Avatar
J Z06
I plan on buying the necessary "Home Depot or Lowes" items and having them put in.
Definitely don't like the recessed look. Flush looks MUCH better.
Old May 21, 2006 | 09:22 PM
Roadking's Avatar
Roadking
I think it is a great looking mod also.
http://cfupload.stevesdomain.net/images/12f3af66d.jpg
Old May 23, 2006 | 07:38 AM
ace1's Avatar
ace1
ttt
To Flush taillights ?
Old May 23, 2006 | 09:33 AM
Vette Dream's Avatar
Vette Dream
Am I the only one that prefers the stock look of the "pushed-in" tail lights?
Old May 23, 2006 | 10:47 AM
Larry_Yerton's Avatar
Larry_Yerton
No. Me too.
Old May 23, 2006 | 10:57 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
i like the look of the flush mount.... but there is something the pics dont show you..... the "cheap" looking weather stripping around each light. close up i think it looks pretty bad since you can see the foam strip around the lights. but to each their own!
