CD player "error"
Old May 25, 2006 | 09:35 PM
LS7 C5's Avatar
LS7 C5
Default CD player "error"
My CD player stopped working, when I put In a CD it says "error" and ejects CD. AM/FM works fine. Anybody have this problem before?
Old May 25, 2006 | 09:36 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Is it the in-dash player?
Is it only with one CD or all CD's.
If it happens only with one I would say that it is the CD itself. I've had my changer balk at a couple of CD's that I burned.
Old May 25, 2006 | 10:22 PM
VLVETTE's Avatar
VLVETTE
Once after my battery went dead and I had to jump start the car. It took about 5 minutes then it started working again.
Old May 26, 2006 | 12:16 AM
AEmedic's Avatar
AEmedic
Same thing happened in my Silverado and I had to replace the whole unit or pay to have it repaired.
Old May 26, 2006 | 12:22 AM
ROD BROWN's Avatar
ROD BROWN
Default I had the same problem
Did you check to see if the CD was placed in the cartridge correctly? I goofed and placed the CD upside down.It made it real hard for the player to function correctly.
Old May 26, 2006 | 07:05 AM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Unplug the power to the changer, then plug it back in. Sometimes that resets it.
jeff
Old May 26, 2006 | 10:20 AM
shannanl's Avatar
shannanl
Mine does that when I add a new CD to the cartridge. I take it back out, slide out the tray with the new CD in it, slide it back in and it works fine. Don't ask me why.
Old May 26, 2006 | 11:19 AM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
time for a mp3 player
Old May 26, 2006 | 08:35 PM
LS7 C5's Avatar
LS7 C5
I have the problem with the dash unit, I don't have the cassette unit in the back of the car.
I only have store bought CDs, It has the same "error" with any of the CDs I try.
Thanks to everyone trying to help me solve this problem!
Old May 28, 2006 | 12:00 AM
TrumpVette's Avatar
TrumpVette
Cruise-In IX Veteran
You inserted the CD upside down
Old May 28, 2006 | 07:44 AM
ebubman's Avatar
ebubman
occassionally but rarely we'll have a cd that won't play. since we got (((xm))) last november we have not played a cd. bub
Old May 28, 2006 | 04:54 PM
artfahie's Avatar
artfahie
It happened to me last week, my windows had been opened while I was parked and my wide says... the CD player has gotten humidity in it.. yeah, right... it's hard enough for ME to find the thing and she's telling me "humidity".
So I turn on the heater and drive for a few minutes... SOB, the thing started working & has been fine since !... Go figure !!!! Good luck with yours.
Old May 28, 2006 | 05:07 PM
kwest2u's Avatar
kwest2u
Old May 28, 2006 | 05:45 PM
phoenixfoundmac's Avatar
phoenixfoundmac
I've got the changer in the rear and it's been pretty touchy ever since I got the car. It plays without hitch about 80% of the time, the other 20% it will give you an error message when you first try to play a Cd. If you switch back and forth between the radio and cd it will eventually go ahead and play. And once it starts playing it never skips or stops. It seems to be the most touchy on really hot days. That's just my experience though.
Old May 28, 2006 | 10:01 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
DId you unplug the CD Player and plug it back in? This should allow it to reset. This happened once and that is what I did. The unit reset and has been fine ever since! Knock on wood!
Old May 29, 2006 | 01:35 AM
red97vette's Avatar
red97vette
ive been having the same problem with mine too latley. some days it will play certain cds, and others i get "err" all the damn time! ughh makes me just want to get an mp3/harddrive headunit (i just dont want to get rid of the 'factory' look though..)
Old May 29, 2006 | 06:05 PM
MyOwn69's Avatar
MyOwn69
Your "WIDE?"
She knows you call her that - you're hurtin' for certain!!
Old May 29, 2006 | 09:00 PM
fireball's Avatar
fireball
Happens with my in-dash unit everytime. The routine is...
1. Insert CD
2. ERR
3. Eject
4. Repeat about 10 times and then it starts working.
PITA!!!!
To CD player "error"
