Hid Lighting Help Needed!!!!!
Old May 27, 2006 | 12:11 PM
SmacZ's Avatar
SmacZ
Default Hid Lighting Help Needed!!!!!
Hey Guys,
I have a buddy that had some HIDS on his SS camaro and one of his lights started to flicker. So he sent it in under warranty to be fixed. In the meantime he purchased another set because he would get it quicker and figured that when the ones he sent out came back, he could drop them in his new Pontiac Solstice.
Well they dont fit the Solstice so he came by yesterday and said " Here, Happy B-day"
The problem is he is not sure where he put the relays ..... am I going to have any problem using them without the relays?? I dont want to fry anything in my car....or will it just burn out bulbs quicker?
Also there are obviously no mounting instructions ....so where do I put the ballasts and all that jazz. Im sure there are some instructions out there somewhere for all the basic HID kits as they are pretty much the same, ballasts, bulbs, harnesses???
Thanks in advance
Shawn
Old May 27, 2006 | 12:18 PM
DeeGee's Avatar
DeeGee
PM NotMee. He sells kits and I'm sure he'd help out a Forum buddy.
My guess would be that the relays are there to control current so I'd be wary about not fitting them if the kit's high power.
But I'm no expert.
Old May 27, 2006 | 12:36 PM
SmacZ's Avatar
SmacZ
But I'm no expert.
I'll PM him and see...
Anyone else have instructions or first hand knowledge ??
Old May 28, 2006 | 10:03 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Ok we just got in from the cruise inn in Bowling Green.
Ill put together some drawings tonight to help you out.
Old May 30, 2006 | 05:24 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
i have attached a circuit layout.
We use a independent relay for each side instead of one for both sides.
Old May 30, 2006 | 11:29 PM
SmacZ's Avatar
SmacZ
Thanks...Im not completely sure how that helps me...Sorry to be so ignorant... LOL
Are there any Generic instructions on where to mount my Ballasts , etc...Also am I screwed without relays????
Old May 30, 2006 | 11:33 PM
garymilgrom's Avatar
garymilgrom
I think you need a set of HID's designed for your Corvette.
If you're trying to re-engineer a package from another car, I assume you have an engineering background and know what you are doing.
Old May 31, 2006 | 12:14 AM
SmacZ's Avatar
SmacZ
Im not try to reverse engineer anything......C5's and Camaro's , Trans-ams, etc all use 9005 and 9006 kits....This kit is the same kit that his father put in his C5....Im just trying to get help with a basic install??
Old May 31, 2006 | 12:20 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
ok call up LAPD they used to install a kit like that.
I can sell you a pair relay harness with all connectors if needed.
The system is more stable with relays in place.
It is a pretty straight forward install.
Ill be glad to help you as much as I can from here.
Old May 31, 2006 | 11:42 AM
SmacZ's Avatar
SmacZ
Cool....People say your a great guy but damm thats service even when its in your own backyard and not your product...Maybe I will step up when I get a chance.....
How much for relays?
I can take a picture of what I have also if that helps?
Old May 31, 2006 | 01:16 PM
c5z06vette's Avatar
c5z06vette
Take it from me, NOT-MEE is a great vendor, he helped me out even though I did not purchase a kit from him (mistake on my part). Do yourself a favor and spend the extra $$ for one of his kits, it will be well worth it.
Old May 31, 2006 | 01:40 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
St. Jude Donor '05 thru '19
done once, done right, Brian knows his stuff.
There were some installs done at the cruise in last week
Old May 31, 2006 | 01:52 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Pic's would help for configuring the harness correctly.
Old Jun 1, 2006 | 02:26 AM
SmacZ's Avatar
SmacZ
How much could you do relays for??
Old Jun 1, 2006 | 07:18 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
I need to see pic of the input connector on ballast (one without wires).
Standard harness both sides with plug-n-play connectors would be 100.00 and ill even include the hi/low beam on at same time option.
Old Jun 1, 2006 | 07:26 PM
SmacZ's Avatar
SmacZ
Cool...Ill snap some photos of the connector when I get home.
Old Jun 1, 2006 | 08:13 PM
DeeGee's Avatar
DeeGee
Now thats a great Forum Vendor
To Hid Lighting Help Needed!!!!!
Old Jun 1, 2006 | 09:13 PM
RPOZ4Z's Avatar
RPOZ4Z
based on my track record, that should be my pic with that caption!
Old Jun 1, 2006 | 09:28 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Old Jun 1, 2006 | 09:34 PM
Humanoid 2.0
