RPO codes
Old Jun 10, 2006 | 07:12 PM
quatermilechic's Avatar
quatermilechic
Default RPO codes
Hey guys I need some help.......I just got my car and I would like to know how to tell what my car options are how do I figure out my codes and such.
Thanks sooo much for any and all help!
J
Old Jun 10, 2006 | 07:26 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://home.fuse.net/corvette/rpo.htm
Old Jun 10, 2006 | 07:28 PM
Barrier's Avatar
Barrier
The RPO codes can be found in your Glovebox or Drivers side rear compartment depending upon year. Then you need the "translation" either from Corvette Action Center website or Idahovette website.
Barrier
Old Jun 10, 2006 | 09:08 PM
Vassili's Avatar
Vassili
If you would like a print out of YOUR car's specs, contact Bob at Fichtner Chevrolet and he'll print one out for you. I'm holding mine right now. 1(406)628-4121
Old Jun 10, 2006 | 10:12 PM
GrayC5's Avatar
GrayC5
Look for your car's Service Parts Identification (RPO) Label. For '97 and earlier model years, the label is on the underneath side of one of the rear storage compartment lids (usually the left side, I believe.). For later model years, the RPO label is on the inside of the glove box lid. This label will show all the RPO codes for your car as it was delivered from the factory. The following link contains one of the most comprehensive lists of C5 RPO Codes that I've found and should help you determine what they mean:
C5 Regular Production Option (RPO) Codes
Also, any GM dealer can inquire GM's Vehicle Inquiry System (VIS) for your car's history and build info if you can just get them to. The build info portion of the inquiry will show all your car's RPO codes as it was delivered from the factory along with its build date.
Service Parts Identification Label:
Old Jun 10, 2006 | 10:50 PM
quatermilechic
Thanks guys ya'll are such a big help!
Here's to ya!
To RPO codes
