Front Spoiler
Old Jun 24, 2006 | 10:28 PM
SSWEET's Avatar
SSWEET
Default Front Spoiler
Recently purchased a 2000 C5 and sold my 88 C4..With the C5 it seems that I scrape the front spoiler constantly...going up drive ways...any slight change in road level seems to scrape much more than the C4 ..is this normal?
Old Jun 24, 2006 | 10:32 PM
keliente's Avatar
keliente
Old Jun 24, 2006 | 10:33 PM
TruUndrtkr's Avatar
TruUndrtkr
That's how it goes..
Old Jun 24, 2006 | 10:34 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Is the car lowered or at the stock height. When my car was at the stock height I very seldom scraped and now slammed it happens all the time and I do not mind as I like the lowered look much more
Old Jun 24, 2006 | 10:36 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I had a 96 C4 and it scraped just about as much as my C5. Has your C5 been lowered? It is easy to do on stock bolts.
Old Jun 24, 2006 | 10:43 PM
T's's Avatar
T's
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
I'm with the others, has it been lowered if not ..... don't do it
Old Jun 25, 2006 | 12:02 AM
Yes, the C5 has a tendency to scrape the front end a lot. Perhaps going up a drive or over a bump at an angle will help.
Old Jun 25, 2006 | 06:44 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
It is normal. On my 99 and I assume on the others, that spoiler is hinged to roll back when its scraped. They were so aware that this is normal, it even says in the manual that the front spoiler may scrape from time to time and you should consider it to be normal. Just go slow when you see those dips at parking lot exits, etc.
Old Jun 25, 2006 | 06:46 AM
SlideRulz's Avatar
SlideRulz
Normal
Old Jun 25, 2006 | 06:49 AM
DeeGee's Avatar
DeeGee
Originally Posted by SlideRulz
Normal
The good news is the front air dam is designed to flex backwards.
I've fitted frame savers and rocker rails:
https://www.aandacorvette.com/cart/s...sp?MainCatID=5
It won't stop scraping but it avoids and damage
To Front Spoiler
