testing (pic)
Jun 26, 2006 | 09:01 PM
testing (pic)
here is the pic of my c5. I just purchased it last Monday. It has red leather interior. I want go get more info on it.
http://img100.imageshack.us/my.php?image=vette9tm.png
Jun 26, 2006 | 09:11 PM
Jun 26, 2006 | 09:13 PM
Jun 26, 2006 | 09:14 PM
Cruise-In VIII Veteran
St. Jude Donor '07
Jun 26, 2006 | 09:15 PM
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Jun 26, 2006 | 09:16 PM
Good looking vehicle.
Welcome to the forum.
It's a coupe
Seriously, what kind of info are you looking for?
Jun 26, 2006 | 09:19 PM
From: Why are there squished peanut butter cups in my underware?
I want to find out if it has a z51 option.
Jun 26, 2006 | 09:20 PM
there ya go, might i add nice looking coupe!, looks just like mine
Jun 26, 2006 | 09:21 PM
Jun 26, 2006 | 09:23 PM
Quote:
Check the RPO sticker.
Jun 26, 2006 | 09:34 PM
Jun 26, 2006 | 09:36 PM
Jun 26, 2006 | 09:39 PM
Is there a way that I can find this info using the vin #
I don't see any codes in the glove box.
Jun 26, 2006 | 10:11 PM
where's the rpo sticker
Open the rear hatch, and remove the small storage lid (it's usually the drivers side) it's on the underside of the lid.
Jun 26, 2006 | 10:18 PM
For model year 1998, the Service Parts Identification (RPO) Label should be on the underneath side of one the rear storage compartment lids, usually the driver's side. Also, using the VIN any GM dealer can inquire GM's Vehicle Inquiry System (VIS) for your car's service history and build info which will show all the options for your car as it was delivered from the factory. If you can't find a dealer to run this for you, several members here also have access to GM's VIS. Start a new post requesting a GM VIS inquiry on your car and include the VIN in your post. Hopefully, one of these members will come along and run this for you. Here's a link that contains one of the most comprehensive lists of C5 RPO codes that I've found:
C5 RPO Codes
Also, here's a link to the Forum testing section which you should use for that purpose:
Testing
HTH and good luck.
Service Parts Identification Label:
Jun 26, 2006 | 10:48 PM
thank you. I am going to look for it tomorrow and post my options.
Jun 26, 2006 | 11:01 PM
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
