Locking Steering Column
Old Jun 30, 2006 | 04:22 PM
jdaniel2509's Avatar
jdaniel2509
Like 888 said, why can't they just remove the fuel kill? That would fix mine.
Old Jun 30, 2006 | 04:28 PM
jdaniel2509
I was aiming that more at RichieRich. If he is a service writer or manager at a GM store, he of all people should have a simple explanation at this point.
Old Jun 30, 2006 | 06:32 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by jdaniel2509
RichieRichZ06
I would think you would be able to tell us what will fix our cars. Again, my 98 auto had NEVER had a problem until I answered the recall. Then the long road of 7 tow ins started. Lock has been removed, K harness put in, relay added, removed and last week added back.........
36 miles after answering the first recall in Nov 2004, my car would not crank because of the fuel kill. That means the fuel kill went in on the first visit. It's obviously STILL in there because everytime I get the "pull key" it shuts off in drive. The dealer is the only place that has ever worked on my car. I have NO CLB. My dealer says they don't have the old program to rewrite over the one that "shuts the fuel off" that was added so WHAT IS THE CURE? I mean this question in the most sincere way. I picked my car up (again) last week and I put it in the garage and it's still there. When I go to leave the house my wife and I look at it and ...............no, lets just drive it some other time. It's a shame.
First off, sorry it took so long to respond. I have been as busy as a one legged man in an a$$ kicking contest. Unfortunately this is a huge problem that has had me on the phone for hours and hour with GM. The best answer that I have so far is that GM said to start replacing the actuator itself. The newer designed act. was used on all late 2004 models, which have never been involved in the recall at all. After Dec 2003 all the '04 models were using that actuator. GM told me that act. does not require a signal to not cut the fuel. We have had to install that act in 2 CF members cars that kept getting the "pull key" message. I explained to GM that these customers frequently went on long trips in their cars and did not want to get stranded in the middle of BFE. So far both the guys cars have not had another problem with this. I have tried to stay up on this info from GM every couple weeks. The procedure does require approval from GM ahead of time, but so far they have all been paid under warranty. I hope all this helps out and let me know if you need any more answers or advice. Our number here is (707)422-7777. Ask for the Parts Manager. RICH
Old Jun 30, 2006 | 06:43 PM
RichieRichZ06
St. Jude Donor '08
[QUOTE=WWK888 Maybe you can answer this for me, why can't GM undo the fuel cut off program that is messing up so many people's cars? I am not asking that in a sarcastic manner so don't take it the wrong way, I just want to know if it is possible.
Thanks [/QUOTE]
Last time I was on the phone with Tech assist I asked them this same question. His answer was "It is a theft deterant issue and so far we can't do that." I was not impressed with the answer either. I would think that it would be able to be programmed out of the PCM somehow. The only problem I see with that solution is that the first time a vehicle is stolen the owner will sue GM for disabling his theft deterant system. I wish that I had more info, but I can only provide the answers as GM presents them. Sorry, RICH
Old Jun 30, 2006 | 06:49 PM
HenryIV's Avatar
HenryIV
Thanks for the post. My car, a '01 Z06 is at the dealer right now waiting on parts for the recall fix , recall # 04006. My dealer has told me I need to have recall 04006 done and also replace the "lock plate actuator" at a cost to me of 375 $ to really fix the problem. I have called 1-800 222 1020 Chevy service line to file an official complaint about this. I have been given a service number and told I will get a call back within 24 busness hours. My service guy says the PCM will NOT be reprogramed in my repair. So what do you guys think? Think chevy will step up the the plate and buy me a new actuator also?
Tom
Old Jun 30, 2006 | 06:59 PM
RichieRichZ06
St. Jude Donor '08
Tom
I would politely throw a fit. GM should cover this and the service manager should be able to pull some strings. At the very least, GM should offer to split the cost 50/50. That has been the case for many out of warranty repairs that are on the border of liability for GM. If the service manager wants to put a little effort into helping you, he can get the ball rolling with his Area Vehicle Manager(basically the regional service manager). He could also call the tech assist center and try to get authorization from them to have it done. It has worked on the two we have pushed through and soon to be on my car as well. good luck and let us know how it turns out. Now I am off for vacation till wednesday. RICH
Old Jun 30, 2006 | 09:09 PM
JD's C5's Avatar
JD's C5
I am still at a loss to understand any of these arguments. I can't find one reason to do anything other than just buy and install a CLB which takes care of the problem. Why worry about the GM fixes if you can put in the CLB. Am I missing something here?
Old Jun 30, 2006 | 11:41 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by WWK888
IMHO...DO NOT HAVE THE RECALL PERFORMED!!!!!
Yes they will remove your locking plate but they will also program your computer to cut the fuel if it detects a problem (whether real or perceived). They have also had problems with the replacement K harnesses. Your best bet in my opinion is to yank on the steering wheel or pull the fuses to get it to unlock then install the CLB. If you do a search you will read the horror stories from people who have done the recall, yes even the latest one in Feb 2006.
Install a Column Lock Bypass.
Turn the ignition key to the off position and remove it from the ignition. Next, firmly tug the steering wheel back and forth several times. Then turn the key to the "on position" without starting the engine and the column lock should release. This has worked for many people including myself.
Once you release the pin and unlock the steering column, do not attempt to start the engine until after you install the bypass or it may lock up again.
Here is a link to the best instructions for installing a CLB:
http://www.ls1howto.com/index.php?article=24
Or just follow the installation instructions that come with the CLB kit. It's really not difficult. You can buy a CLB for less than $50 at Corvettes of Houston or Thunder Racing.
http://www.thunderracing.com/catalog...d=220&pcid=156
http://www.corvettesofhouston.com/pr...5d8c4a9482090f
Old Jul 1, 2006 | 12:13 AM
HenryIV's Avatar
HenryIV
My reason is that I waited untill my column locked for the first time (thursday night) to look into the issue. By the time I found this thread my car was already towed to the dealer to get the column unlocked. Once your column is locked the CLB is no real help. I tried all the side to side pust pull stuff and my column would not unlock period. I am a personal friend of the local Chevy dealership's owner, so I think I can get his help trying to get GM to pony up the parts needed.
Old Jul 1, 2006 | 09:05 PM
Mike98SilVert
As I posted:
"Turn the ignition key to the off position and remove it from the ignition. Next, firmly tug the steering wheel back and forth several times. Then turn the key to the "on position" without starting the engine and the column lock should release."
The dealer will use this same method to get your column unlocked so he can perform the recall. If the dealer is a personal freind then ask him not to perform the recall and just have him install a CLB instead. You will be much better off.
Old Jul 1, 2006 | 10:33 PM
Virtual Geezer's Avatar
Virtual Geezer
There are three major things the Corvette Forum has given me:
1. The camaraderie of fabulous fellow enthusiasts.
2. Introduced me to Ken King and the superb products from Vette Essentials.
3. The Column Lock Block.
Get the block, install it and worry no more.
I have a late '04 MN6 coupe, allegedly NOT included in the recall, and I put one in anyway.
Old Jul 1, 2006 | 11:48 PM
JC in XTC5's Avatar
JC in XTC5
I have an '00 MN6, and installed the CLB when the car was about a week old. The best thing I did besides the CAGS Defeat.
Old Jul 3, 2006 | 10:45 AM
  #33
HenryIV's Avatar
HenryIV
Thanks for the advice. At 1pm today I will recieve a phone call from the dealer/owner telling me what Chevy will do for me. If they don't treat me fairly, then I will take your advice and cancel the recall work and go with the aftermarket workaround.
Old Jul 3, 2006 | 08:29 PM
  #34
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
My "service column lock" message just came on today. But I have a nearly dead battery and the column is not locked...wonder if it will?
Old Jul 5, 2006 | 11:18 AM
  #35
jdaniel2509
Rich
Would replacing the actuator on my 98 with the newer one help me even though I've had all the recalls and the fuel shut off is my problem?
Old Jul 5, 2006 | 07:30 PM
  #36
RichieRichZ06
St. Jude Donor '08
Rich
According to GM, YES. They told me and a tech that the newer actuator does not require the signal to say everything is OK before allowing it to start. So far it worked on the two vehicles we have done it on and they have not been back for the same problem again.
Old Jul 5, 2006 | 10:40 PM
  #37
HenryIV's Avatar
HenryIV
Default Got it back today
I got my '01 Z06 back today. The owner of the local dealership really went to bat for me with GM. He called the area rep at home on her cell phone, as GM was off for the 4th of july week break. He got her to sign off on the repair as Warranty work even though my car is 5 1/2 years old. I got the recall, the actuator, and the Tow-in for 0.00$ thanks to the owner's efforts on my behalf. Needless to say I am a happy camper. I feel like Chevy did right by me.
To Locking Steering Column
Old Jul 6, 2006 | 10:22 AM
  #38
RichieRichZ06
St. Jude Donor '08
Excellent. It just takes a little more effort on the dealerships employees side!
Old Jul 10, 2006 | 12:37 PM
  #39
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Once GM fixes my car will the CLB work and keep the fuel from shutting off if their fix should fail again?
Old Jul 10, 2006 | 01:28 PM
  #40
jdaniel2509
Tact,
Thats what I'd like to know. I have a CLB but I have not put it on.
