Rear Differential
Old Jul 5, 2006 | 03:33 PM
Bracketman's Avatar
Bracketman
Default Rear Differential
Took my 98 A4 to the local Chevy dealership here in Alberta since I found a drip coming from the rear end. After putting the car up, noticed it was coming from the rear differential. The manager of the dealership was actually the one talking to me about the problem, stating that he owns a 2000 and has had the same problem. He then stated that there are special tools (that cost $30 grand according to his sources) that are needed to get to the differential, and that it will cost me $1200 CAN for 12 hours of labour (since virtually the entire rear end has to be removed) and then the cost of the parts.
Was going to phone around to some transmission specialists, but I need to know if there are special tools that have to be used to get access to the differential, or if the Chevy manager is giving me a story.
Old Jul 5, 2006 | 03:37 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
don't go back there, that does not sound right at all. If it is the leaky gasket that is common is like a 3 hr job with no special tools needed as far as I know.
Old Jul 5, 2006 | 03:55 PM
csexton's Avatar
csexton
Took mine in with print outs from this forum showing how common the problem was. My car was out of warranty and service dept. said they would pay half. It cost me $180.00. Go to another dealer!
Chuck
Old Jul 5, 2006 | 04:02 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Here are some prices.: http://forums.corvetteforum.com/show....php?t=1071230
Old Jul 5, 2006 | 04:05 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
...and here are the list of tools needed. http://www.cajundude.com/outputshaftseal.htm Tell you what, I'll sell you every tool listed for $15K. Heck that can even be in Canadian dollars.
Old Jul 5, 2006 | 04:21 PM
Find yourself a different dealer. Shouldn't cost anywhere near that amount of money to fix the seal.
Old Jul 5, 2006 | 04:32 PM
keliente's Avatar
keliente
LOL, I just read the " Tap taparoo. " part and laughed my butt off. Billy Madison for the win!!!
Old Jul 5, 2006 | 04:47 PM
GrayC5's Avatar
GrayC5
I had mine fixed under factory warranty several years ago. Although the invoice didn't show prices, it did show labor hours and parts which included the following:
1.9 (1 and 9/10) hours labor
1 axle seal
1 differential cover with seal*
2 gear oil
1 lubricant
*The mating surface on my old differential cover was also scored and they replaced this along with a new cover seal. If your cover's surface is OK, you may only need the cover seal here.
I would certainly question any shop that would attempt to charge you for many more labor hours or parts than shown above.
Good luck with the repairs.
Old Jul 5, 2006 | 05:06 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
I have an appointment on the 17th for my 01'. I know they came out with a improved gasket which costs 12.00 and I am having the whole job done for 200-300 at a local speed shop.
Old Jul 5, 2006 | 05:18 PM
Bracketman's Avatar
Bracketman
Got a little more information from the Manager I talked to earlier. He said that the tech said it was coming from the Driveshaft Input Seal, if theres any difference to the suggestions from above.
Old Jul 5, 2006 | 05:20 PM
Bracketman's Avatar
Bracketman
And that price was a quote - no way I was saying "ya sure" to that until I found out some more information.
Old Jul 5, 2006 | 06:29 PM
GrayC5's Avatar
GrayC5
This is a totally different seal from the axle (output shaft) and differential cover seals that we were lead to believe and discussed above. There are also other seals to be found between the transmission and differential. You need to find out specfically which seal(s) they are speaking about. The work involved will be dependent on which seal(s) and replacement of some of these can in fact require dropping various parts of the driveline to include the transmission, differential, etc. I would recommend that you speak directly with the tech and have him show you exactly which seal(s) that he is speaking about and show you specifically why he believes they need replacement. Until you can provide all the exact specifics to include which seals, the folks here can't be of much help to you.
Good luck.
Old Jul 5, 2006 | 08:26 PM
vettesmith02's Avatar
vettesmith02
My '02 is going in next week for diff leak, under warranty at 9400 miles.
I need to start driving it more.
Old Jul 5, 2006 | 08:51 PM
Blowtorch's Avatar
Blowtorch
Good luck.
I concur. To repair the rear trans extension seal requires dropping the transmission and rear gear and even the cross member if I remember correctly. That can get expensive. You need to find exactly what they are refering to.
Old Jul 5, 2006 | 09:21 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
$1200 to fix a drip? You might consider the Cartalk guys advice and let it drip until you're ready for some gears or a converter.
Old Jul 5, 2006 | 09:26 PM
Dark-Knight's Avatar
Dark-Knight
He's trying to rip you off!
Old Jul 5, 2006 | 09:57 PM
oaks99's Avatar
oaks99
don't walk run away
To Rear Differential
