how often
Old Jul 18, 2006 | 09:38 PM
tjcvett's Avatar
tjcvett
Default how often
How often do you change your belt? Mine's 6 years old and has 23,000 miles. Looks great and have no problems, but should it be changed? Thanks.
Old Jul 18, 2006 | 09:48 PM
csexton's Avatar
csexton
I changed mine at 5 years, 20000 miles. Belts were dry and worn.
Chuck
Old Jul 18, 2006 | 09:55 PM
rws.1's Avatar
rws.1
5 years or 100,000 miles
Old Jul 19, 2006 | 05:45 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, I have 12,000 miles on my 5 year old C-5 belt, and it still looks OK and runs quietly. However, I just had to replace the belt on my Z-28 a couple of days ago. The car is 10 years old, with 63,000 miles. I've replaced it at least once before, however it just started squealing when I would turn on the a/c. There are no cracks, or any visible damage, but it just lost "traction".
Old Jul 19, 2006 | 07:56 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
It's really dependant on a number of variables; millage, damage, heat etc. A belt needs to be inspected on an annual bases. Any visual damage; cracking or brittleness is a good indication that its time to change. Another substance that causes them to deteriorate is ethylene glycol. Leeks in the system that come in contact with belts also causes them to degrade over time and accelerating their replacement.
Old Jul 19, 2006 | 09:58 AM
cooluhl's Avatar
cooluhl
Just changed the one on my Tahoe with 130000k miles on it. Still looked good, but the tensioner started squealing.
Old Jul 19, 2006 | 12:34 PM
bandit_99's Avatar
bandit_99
I just changed mine when I did an underdrive pulley and my stock belt from 99 was starting to look sad. 50k miles on the clock.
Old Jul 19, 2006 | 12:41 PM
roscoe118's Avatar
roscoe118
Originally Posted by tjcvett
How often do you change your belt.....
Every time I go out to Italian food
Old Jul 19, 2006 | 12:55 PM
EscapePod's Avatar
EscapePod
I'm getting tensioner squealing on mine now. Is there some way to lube that (internally, not the belt surface )?
Or.... did the squealing stop when you changed the belt?
Old Jul 19, 2006 | 12:58 PM
srchief100's Avatar
srchief100
Old Jul 19, 2006 | 02:47 PM
kalister1's Avatar
kalister1
Default How long NOT to wait
Change it before it looks like this, the cracks! I know it's dirty. Also don't let your hoses do this!
To how often
