[Z06] Valve Spring Change-How Difficult
Old Jul 19, 2006 | 09:46 AM
72Shark's Avatar
72Shark
Default Valve Spring Change-How Difficult
Any issues with changing my valve springs/rocker arms at home? I've done it many times on my other older vettes using compressed air and a valve spring compressor. Can this be done with the LS6 also? Or is this an "expert mechanic" job? I want to get away from the threat of a broken stock spring, and step up to improved roller rockers. Thx.
Old Jul 19, 2006 | 12:30 PM
TransAmGT's Avatar
TransAmGT
You shouldn't have a problem if you have done it before. I did it on my LT1 with no experience at all...I'm sure there is any online guide on HOW-TO...just follow it to the T and you should be fine!
Might as well throw a cam in there whlie you are at it!!
Old Jul 19, 2006 | 05:44 PM
Z06-Nomad's Avatar
Z06-Nomad
To Valve Spring Change-How Difficult
