HELP... battery problem
Old Jul 29, 2006 | 04:00 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default HELP... battery problem
can anyone help. i have had the lights up with only the fogs on while i washed it, after washing it iput in some new fog bulbs and contiuned wiping. i noticed a buzzing coming from the fuse block by the battery and started to investigate. it was the fog micro relay that was buzzing. humm.. so i started to put the old bulbs back in and the 1st one didn't work, so i noticed the light under the hood was off, i goes off after a while normally so i get in to turn the key and the batt is dead. i got the car in feb so i don't know how old it is but it looks new. could the relay have caused the battery to go dead?
Old Jul 29, 2006 | 04:07 PM
Dave68's Avatar
Dave68
I think the relay buzzing is a result of a weak battery, not the other way around. Have your battery checked; it may be time for a new one. I recommend the Exide Orbital if you want to stick with a leakproof battery.
