Convertable top adjustment help needed
Old Aug 8, 2006 | 01:07 AM
torch2000vert's Avatar
torch2000vert
Default Convertable top adjustment help needed
I have a recent problem with my convertable top. When I open and close the hard boot it rubs the rear of the top on the lowest center part of the hardboot. I'm hoping someone else knows if there is an adjustment that applies to my problem. Any ideas?
Old Aug 8, 2006 | 01:17 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Although the tech tip states it's for an '01 - I think this would work for any year C5 convertible....
http://www.c5forum.com/diy/01topfix.php
Old Aug 8, 2006 | 02:17 AM
torch2000vert
Default Thanks for the link but thats not were mine is rubbing
Randy,
Thanks for the link but thats not were mine is rubbing, check out revised pics.
Old Aug 8, 2006 | 03:05 AM
GrayC5's Avatar
GrayC5
This is quite common and I don't know that there is much one can do as far as adjustments go. The center of the stowage compartment lid is actually rubbing on the cloth flap that lays on top of the lid when the top is up. In the later model years, GM added a reinforced rub strip to the cloth flap where the lid rubs it. Our '03 has this added rub strip. I've gotten into the habit of lightly pushing the cloth flap away with the fingers of my left hand while closing the lid with my right. Good luck with yours.
Old Aug 8, 2006 | 03:27 AM
DeeGee's Avatar
DeeGee
Mine has the same problem. I suspect GM fitted the rubbing strip for that very reason.
Old Aug 8, 2006 | 07:11 AM
rws.1's Avatar
rws.1
Same rub here on the '01.
I have not seen a fix for this posed on the forum
Old Aug 8, 2006 | 08:37 AM
Drop Top's Avatar
Drop Top
Old Aug 8, 2006 | 08:58 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I just checked my '98, it rubs that flap also, I suspect that it's always done that and it doesn't cause any problems. there are no marks on the tonnau cover from it.
Old Aug 8, 2006 | 09:48 AM
blacksedan87
Originally Posted by torch2000vert
Randy,
I have the same spot on my '98 too. I figure that if it ever becomes a huge problem, I'll have the tonneau cover repainted (because I do have a slight rub mark on mine) or eventually the top will be replaced. I honestly don't think there's a fix for this other than to do what Jim said -
Sorry the link was of no assistance, but we tried, right?
Randy
Old Aug 8, 2006 | 10:08 AM
barrynk's Avatar
barrynk
My 2001 has the same issue, never noticed it to be a problem, doesn't seem to be any wear on the boot or the top.
I also have the reinforced rub strip.
Old Aug 8, 2006 | 10:20 AM
dougbfresh's Avatar
dougbfresh
I have noticed on my 01' that if you get the top in just the right spot, it does NOT rub, takes a little practice. Seems like they could have engineered this a little bit better. I would imagine the only real adjustment for this in the bolts at the pivot point insode the quarter panels. The top needs to move FORWARD a fraction.
Old Aug 8, 2006 | 12:03 PM
torch2000vert
I think you hit the nail on the head, I will try to move the top forward a bit on its mounts. If it works I will post the results. Thank you everyone for the feedback.
Old Aug 8, 2006 | 02:57 PM
GrayC5's Avatar
GrayC5
I would give this some careful thought and consideration before doing it. If not careful, you could create much worse problems such as the ones in the link below and in the link Randy posted in his first reply above.
Good luck.
To Convertable top adjustment help needed
