Codes
Old Aug 12, 2006 | 01:27 PM
LMB-Z's Avatar
LMB-Z
Default Codes
Can anyone please tell me what these codes mean? AO-LDCM-4 codes: B2284H, B2282H, B2262H, & U1064H; A1-RDCM-4 codes: B2283H, B2285H, B2265H & B1064H; BO-RFA-3 codes: U1000H, U1255H, & U1064H.
I have no idea what these codes mean or what to do. Please help.
2001 Millenium Yellow, auto., coupe.
Old Aug 12, 2006 | 01:30 PM
OrangeVegaGT's Avatar
OrangeVegaGT
St. Jude Donor '06-'07
No doubt someone will son post a link to all the codes, but I can tell you that all of them having an "H" at the end are historic codes and have been resolved. They do not indicate a current problem.
Are you having a problem with the vette?
Old Aug 12, 2006 | 01:51 PM
DeeGee's Avatar
DeeGee
Heres a link to a code list:
http://www.97vette.com/howto/codes/index.html
There seems to be a bunch of random codes. One is loss of comms with the Body Control Module. Guessing but that may throw up others in sympathy. Do you have an old battery? If so it may be on its way out. That can cause random electrical problems.
As OrangeVegaGT says the H means the problems have cleared. You could reset them and see if any reoccur.
Old Aug 12, 2006 | 02:10 PM
OrangeVegaGT
From reviewing those codes it looks like a bad battery was a real good pick by DeeGee.
Old Aug 14, 2006 | 03:55 PM
LMB-Z's Avatar
LMB-Z
the battery looks as though it has been replaced. The car has an aftermarket alarm system, and as far as I can tell, whoever installed it, did a **** poor job, excuse my french. They removed some of the air conditioner parts from under the dash. I am having an a/c problem, blowing hot air on the drivers side and cold on passenger. I have since removed the old codes, disconnected the battery overnight, and still no cold drivers air.
Old Aug 14, 2006 | 05:12 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I am thinking you may want to check things out under the battery - it seems to me that last symptom you mentioned (the AC not working) has been caused by vacuum lines that have corroded by leaking batteries. If the vacuum lines (which are right under the battery tray) got leaked on, chances are some of the wires in that area may have also been damaged...
Old Aug 14, 2006 | 08:31 PM
JGreen's Avatar
JGreen
I thought that the "H" after the codes indicates that there was once a problem, but it is corrected now?
Old Aug 15, 2006 | 06:22 AM
Crooze's Avatar
Crooze
Yes.. The "H" means it's no longer detecting the problem.
I would clear all of the codes, drive it for a day or 2 and check them again.
To Codes
