01 Z06 Headlight Problem
Old Aug 13, 2006 | 12:12 PM
Dub Silverado's Avatar
Dub Silverado
Default 01 Z06 Headlight Problem
I have an 01 Z06 and when I turn off the headlights they both go down alright but the drivers side motor will continue to run for about 10-15 seconds after they have both gone down.
Any ideas why?
Old Aug 13, 2006 | 12:39 PM
JC in XTC5's Avatar
JC in XTC5
Do a search on this topic - there are many posts about this type of problem.
If you hear the headlight motor continuing to run after the door closes, the plastic gear in the motor is likely stripped - an aftermarket brass gear can be installed to fix it.
If the door continues to reopen after it closes, then the plastic stop that the motor arm contacts is broken or missing and needs to be replaced.
Old Aug 13, 2006 | 12:43 PM
DeeGee's Avatar
DeeGee
Any ideas why?
Is it associated with a grinding noise?
Old Aug 13, 2006 | 01:05 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You can read all about the headlight gear issue in the sticky post at the top of the page - but here's a link to make it easy for 'ya....
http://forums.corvetteforum.com/showthread.php?t=984927
To 01 Z06 Headlight Problem
