Dumb Jack Stand Question
Aug 14, 2006 | 08:18 AM
Where is the best place to position jack stands on a C-5? I don't want to mess anything up!
Aug 14, 2006 | 08:35 AM
I put mine just inside the A-arm attachments to the frame.
Aug 14, 2006 | 08:48 AM
Here you go
Aug 14, 2006 | 08:50 AM
CI 3-5-6-7-8 Veteran
^ That's out of the service manual... I put it on each side of the front/rear sub-frames just inside of the A-arm... probably where Tom puts his.
Aug 14, 2006 | 08:57 AM
Here is a pic where I put the rear jack stands
Aug 14, 2006 | 09:02 AM
^ Nice T1 pipes Tom
Aug 14, 2006 | 10:41 AM
Same place as Tom puts his, never had issue. It's been up on them for the last 3 weeks because I'm lazy and it's 105 freakin' degrees in my garage every day
Aug 14, 2006 | 11:42 AM
Be careful when jacking up the rear!!!
Parking brake and in-gear (manual) only works on the rear wheels. When you lift the rear using the typical hydrauic jack, the action of the jack may pull the car to the rear. There was a post a few months back about a car on ramps in the front where the person had it roll as he was jacking up the back. Please remember to chock your wheels...
Aug 14, 2006 | 11:50 AM
Quote:
Originally Posted by Cobra4B
^ Nice T1 pipes Tom
WOT
Aug 14, 2006 | 02:17 PM
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Check out
www.z06vette.com , great pics & instructions. " DIY- Lift your car without pucks"
Aug 14, 2006 | 03:10 PM
Quote:
Wow! Color-matched jackstands. Here in Ga we use those cone-creet blocks. I suppose I could paint them.
DBD
Aug 15, 2006 | 07:21 AM
Thanks for the help!
Aug 15, 2006 | 08:00 AM
Quote:
DBD
paint your car gray ?
