Active Handling problem still there
Old Aug 17, 2006 | 07:21 PM
DeeGee's Avatar
DeeGee
Default Active Handling problem still there
I had my EBCM replaced recently and I thought all was well,
Today I've had more AH problems
The snag always occurs when I'm stationary at the lights. The outside air was 108F today.
This time its a Service Vehicle Soon Caption with an AH trip. The TCS is still operating and I can select it on and off with the button. The problem clears when I turn off the car and restart. Its thrown a C1287 code which is Steering Sensor Rate Malfunction.
This doesn't make sense to me as its occurring when I'm stationary.
Any thoughts, particularly why it only seems to happen when its hot.
Old Aug 17, 2006 | 07:28 PM
SuiVette's Avatar
SuiVette
I had some issues with the Active handling error message popping up.
It turned out there was a steering wheel locater switch that was shorted out. Had the dealer swap in a new one and no more AH error messages.
Before the fix the AH error message would go off if i was stand still or on the freeway. Took awhile to figure out that this was the cause.
Hope this helps,
Sui
Old Aug 17, 2006 | 08:05 PM
RedRider98's Avatar
RedRider98
I feel your pain, brother. I keep getting a C1281 code which also relates to the steering wheel position sensor.
Old Aug 17, 2006 | 08:18 PM
DeeGee's Avatar
DeeGee
I had the problem fixed originally under GMPP
I may just throw it back at them.
Thanks for the comments
Old Aug 18, 2006 | 08:34 AM
DeeGee's Avatar
DeeGee
Any more thoughts?
Old Aug 18, 2006 | 01:30 PM
99FewteRC5's Avatar
99FewteRC5
sounds like a steering position sensor.
Old Aug 18, 2006 | 03:25 PM
BrianWe's Avatar
BrianWe
I keep getting the codes for the steering wheel position sensor also. It only happens after sustained driving of 2-8 hours on the highway. Goes away after the car cools down and is restarted. Anyone know how much this will cost to get fixed?
Old Aug 18, 2006 | 05:39 PM
DeeGee's Avatar
DeeGee
Anyone any idea how it operates and why I'd get a snag when stationary? I seem to remeber from an old post that it does a check in the few minutes after start and if it gets a bad reading from the sensor throws up a code.
To Active Handling problem still there
