Run flat fix?
Old Aug 26, 2006 | 06:47 PM
levorr's Avatar
levorr
Default Run flat fix?
I just found out that my rear right tire is flat, i didnt have enough time to go around and ask for qoutes, but i did stop after work in a tire kindom if they can fix the flat (my main consern was the sensor- i wanted to make sure they know how to fix the flat without destroying the presure sensore), anyway the guy at the tire kindom place said that in 9 out of 10 times trying to fix a flat on a run flat, the tire rips while trying to remove it from the rim, and it requires buying a new tire (or 2 in my case- they are getting old, and i dont want to run on one new and one old tire in the rear).
like i said, i didnt have time to go around to other tire stores to ask if its right, so before i do, can anyone here verify if what the guy told me is true, or does he just trying to sell me some new tires?
Old Aug 26, 2006 | 06:50 PM
DeeGee's Avatar
DeeGee
There's no problem with taking them off the rims. I still have half tread on my OEM runflats and I'm saving them as spares.
The main issue with a fix is whether its damaged the sidewall. If the nail went in through the tread it's fixable.
I'd say find a dealer who isn't trying to you.
Mind you, if the tires are worn it could be time to go for a new set.
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
He wants your money.
Old Aug 26, 2006 | 06:58 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I have Firestone FireHawk RF's and had a slow leak from a nail in the tread. Took it to my local Discount Tire and they put a plug in it gratis.
Old Aug 26, 2006 | 07:01 PM
Mr.DJ's Avatar
Mr.DJ
Dependant upon the age and condition of your tire...
Although the tire sidewall is somewhat more stout, especially considering it's a low profile tire, if the tire shop utilizes enough care, diligence, as well as an adequate amount of tire soap, then they should be able to dismount it from the rim portion of the wheel without ripping the bead.
Personally, if a tire shop told me what they told you, I'd look elsewhere for a more qualified tire shop to perform the work.
Old Aug 26, 2006 | 08:46 PM
gja's Avatar
gja
I had a nail in the middle of my tread, which caused me to lose 1psi per day.
Just Tires (a franchise owned by goodyear) was able to repair it for $50.
Old Aug 27, 2006 | 12:44 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
I work at a tire shop, and I can say it IS more difficult to demount runflats due to there stiff sidewalls, but it definitely is possible with care. Also, the sensors are not a problem if the tech knows where they're at and not put the "shovel" on the valve stem to break the sidewall seal!
Old Aug 27, 2006 | 01:03 AM
The guy at the tire store is just trying to sell you tires, that's all. I've had a number of runflats repaired and never a problem.
Old Aug 28, 2006 | 09:53 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
That is akin to rape...........should be more like $10 (that's with a Goodyear patch/plug combo)
Old Aug 28, 2006 | 09:59 AM
filmelf's Avatar
filmelf
St. Jude Donor '06-'08
Had 1/4 inch bolt go through one of mine discount tire fixed it with no $10.00.
Find a better place, those guys would probably screw up your rim too.
Old Aug 28, 2006 | 12:12 PM
fixvet's Avatar
fixvet
If you take the tire off the car, my local tire guy doesn't charge anyone for a plug fix, whether you bought tires from him or not. Just good business!!
I had 2-3 of my old GY runflats plugged. No problems!
Old Aug 28, 2006 | 12:39 PM
bozo4onion's Avatar
bozo4onion
You guys sound WAY optimistic to me. Nobody would touch mine. All said "Goodyear doesn't recommend repairing them". My flat (not sidewall) cost bout' $300 to repair (by replacement of course). Sounds like liability issues to me.
Old Aug 28, 2006 | 12:54 PM
FASTFORM's Avatar
FASTFORM
My buddy has a plugged and patched runflat on the left rear and no problems.
Old Aug 28, 2006 | 02:01 PM
seering's Avatar
seering
A local Kaufmann (spelling?) is my vote
Prices on tires havent been to much higher than elsewhere.
They seem to have employees that know what they are doing.
Last time around they asked if i had jacking plates i prefered them to use...
They have refused to simply jack one side, insisted on putting the car on the lift (unless i was in a hurry and insisted otherwise) to remove and patch a simple nail. Not sure but he mentioned they no longer use plugs .. they remove all tires from the rim and patch it from the inside ...
But i have yet to have them charge me for fixing flats.
I know a few places that will fixem no charge for tires you bought there, but since im in the system zero even for the wifes car that hasn't gotten its new set of shoes since leaving the dealer.
Not sure if all the shops are like that ... or just this one .... but the local one has my business.
Old Aug 28, 2006 | 02:05 PM
sxeC7's Avatar
sxeC7
If I was planning to do a lot of high speed driving, like at the track, I'd definitely go for replacement. But for normal driving, a quick plug works fine.
Old Aug 29, 2006 | 01:27 AM
c5coast's Avatar
c5coast
Took mine to DT today...15 for flat repair and 10 for balance....shop knew their stuff...opened doors and hatch..top was off...used high speed plug or was it the glue and spin balance...even torgued the lugs and had the torgue checked by another....$25 well spent in my book
To Run flat fix?
