the red calipers
Old Aug 28, 2006 | 02:02 PM
gillettij's Avatar
gillettij
Default the red calipers
Is 316.95 for brand new GM calipers the right price?
To me, it sounds right, but so many times the forum has many other ideas on where and how to purchase certain items. I'm gettin ready to change my tires and wheels and I thought it would be an excellent time to change the calipers as well. Also, the ceramic brake pads would probably make sense at this time. Any suggestions / comments?
Old Aug 28, 2006 | 02:11 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
You can paint them yourself for about 1/10th that cost. The only difference between the red Z06 calipers and the standard C5 calipers is the red color.
If you buy Rustoleum, it will cost you about $5 in paint - and you'll have enough left over to buy a good quality paint brush and a couple of cans of brake cleaner - and you'll still have change left over.....
If you NEED new brake pads - I say replace them - if you don't - why do it?
Old Aug 28, 2006 | 02:14 PM
BlueDream's Avatar
BlueDream
I'd just paint my existing calipers instead of swapping out and spending money for a new set.
Old Aug 28, 2006 | 02:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I went with silver with red letters.
Old Aug 28, 2006 | 03:39 PM
Mr.DJ's Avatar
Mr.DJ
Any particular red color (specific paint code) that most are using and what color should the Corvette lettering be painted...thanks?
Old Aug 28, 2006 | 03:44 PM
Streetgrime's Avatar
Streetgrime
anyone have a pic with red calipers with STOCK wheels ... preferably in a '98 model.
Old Aug 28, 2006 | 03:48 PM
blacksedan87
You mean like this?
Old Aug 28, 2006 | 04:01 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
just painted mine (the paint is stil wet) black gloss and black gloss on the rotor center... corvette letters shiny alum. looks fine to me....$4.79.
Old Aug 28, 2006 | 04:18 PM
rws.1's Avatar
rws.1
Rustoleum Sunrise Red ... Brush on
$3.47 at Walmart
Old Aug 28, 2006 | 04:40 PM
Streetgrime
OOOOoohhhh VERY NICE!!! but I dont have those cromed out wheels... hah anyone have the same thing with the brushed looking wheels? I imagine it looks good still...
NICE THO!!! damn
You mean like this?
Old Aug 28, 2006 | 04:42 PM
No need to spend $316 on new calipers when they are exactly the same as you have only powdercoated red. Buy a brake caliper painting kit for around $30 (or even less if you buy some spray paint) and do it yourself. Or you can have Corvette Pilot powdercoat you a set for $200 exchanged.
Old Aug 28, 2006 | 05:30 PM
Hammie's Avatar
Hammie
I still haven't grasped how you all perfectly mask your CORVETTE lettering when painting these calipers so they come out with the letters exposed.
Old Aug 28, 2006 | 06:08 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
You don't. Use a sanding block and/or exacto knife to get any paint off the letters.
Old Aug 28, 2006 | 06:24 PM
gillettij's Avatar
gillettij
Okay, I'd Rather Do It Myself And Save Some Cash!!!
Do I Need To Take Them Off, And If So, Is There A Link Showing The Right Way To Do It????
Old Aug 28, 2006 | 06:26 PM
gillettij's Avatar
gillettij
My Other Idea Was To Have The Garage That Will Be Changing My Tires And Wheels Out To Exchange My Calipers For New Ones And Then Paint The Old Ones Really Nice And Sell Them On Ebay. Does That Sound Stupid?
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
PM CorvettePilot (Mike). He has been doing powdercoated calipers for Forum members. Great price and an excellent job with almost any color combo you can come up with.
See this link: http://forums.corvetteforum.com/show....php?t=1302261
Heres mine he did:
Old Aug 28, 2006 | 08:15 PM
blacksedan87
Hammie - the easiest way to "unpaint" the Corvette word on the front calipers is wait until the paint is almost dry. Mine were just slightly tacky to the touch. I got a brand new utility knife blade and literally scraped the paint off the letters. The cool thing was that I had fully formed letters in red on the floor when I was done.
As far as removing the calipers - not necessary. I used the G2 Folia-Tec kit which is a two stage epoxy. I painted the calipers right on the car, fully mounted. In retrospect, I wish I had at least unbolted them and fashioned a hanger so the caliper wouldn't be hanging by the brake line. I also painted the "carrier", and wish I didn't when I was done. It should be black.
Since that time - I had a set powdercoated, though not by CorvettePilot. I have seen his work though - and he does a beautiful job. If you can scrounge up an extra set of calipers, so you don't have to remove yours or if you are willing to tie your car up for a week or so - the best way to have them powdercoated is to send him a set. The turnaround is very quick. If you wait until he has his extra set available - you're in for a long wait...there's a waiting list.
Like anything else - the outcome is only as good as the time you put into preparation and performing the task. If you do it real quick - it won't look as good as if you had taken your time.
To the red calipers
Old Aug 28, 2006 | 09:19 PM
Z0SLIK's Avatar
Z0SLIK
You mean like this?
Looking good!
Old Aug 28, 2006 | 09:29 PM
Hammie's Avatar
Hammie
See this is where I had my problem. I see they're stock white letters, but if you use a knife on them, couldn't you scratch up the white lettering underneath? Also, if you're carving paint off the top, why doesn't the paint of the SIDE of the raised letters raise up a little? If it's applied to a smooth surface on the side of the letters (you can't possibly sand those effectively) I would expect the paint to find its way off the side of the letters once the tops have been cut out.
Did you sand your calipers or just clean and paint them?
And to the threadstarter, I apologize for hijacking the thread, I have always wondered about painting my calipers though.
Old Aug 28, 2006 | 09:41 PM
blacksedan87
First of all, Hammie - they're not white. They're raw metal. They are just raised. With a sharp blade against the letters, your not hurting the metal, just exposing it. Go out to your car and look closely at them and you'll see what I mean.
I too apologize to the originator, but if Hammie has questions, others might as well, and maybe this will clarify the process for someone else.
