new tires fix code issues..
Old Aug 28, 2006 | 04:47 PM
joec's Avatar
joec
Default new tires fix code issues..
I was getting C1226 codes for a while after buying my car.. They always went away after a restart, but had me checking whether I had to replace stuff... Anyway I got rid of the run flats since they were toast and put on a new set new Sumho ASX's and the 1226 codes are gone??? Even when I go over a pretty good bump.. One thing I did do what disconnect the pixtails going to the wheels, so I guess that could've done it also.. The pins in the connectors did look ok to me... I do think I'm still getting the U1094/6's though but will hope that redoing the grounds resolve that..
Wierd Huh...
Thanks all..
/joe
Old Aug 28, 2006 | 07:57 PM
WilliamCall's Avatar
WilliamCall
I assume that the 1226 code was a chasis code (C1226). Which happens to be excessive wheel speed variation on the right front wheel. The U1096 code is a network code flagging the loss of communications with the IPC. All of this could be related to corroded contacts or a bad ground.
