Car runs low 7's in the 1/8th, which equates to 11's in the 1/4. I will also be adding NS, and know I will be required to have a roll bar or cage. I want to have the required equipment, but don't like the idea of having the cage extend down past the driver and passenger seats. You know, the part that has to swing open like the door to get in the seat. If this is ultimately required, can it be removed w/ pins for daily driving. Can I get away w/ not having it? Thanks for the help.
5 point is required so you will have it at least on the drivers side. The door bars are removable so when your not racing just take it out. Bar In Bar Out
Thanks, just what I wanted to know. Is yours a bolt in or weld in? Where did you purchase it, if you don't mind me asking?
Forum member Jason (CAJUNDUDE) is the guy who can build and ship you a nice roll bar.
Thanks for the help. Still don't quite understand the seat and harness thing! Looks like it comes up though the seat about 4-5" from the front of the seat. Does it come across the front of the seat and then through a slot in the seat cover?
Guess I got the answer before your edit. OK there is a bracket that attaches to the seat which allows the installation of the 6 point harness. Nothing comes through the bottom of the seat. You actually sit on the part that you see in the photos.
