Bad CAGS Eliminator??
Old Sep 11, 2006 | 12:29 PM
rcarl's Avatar
rcarl
Default Bad CAGS Eliminator??
I installed a CAGS Eliminator about a month ago. Friday threw code- P0803 1-4 Upshift Solenoid Control Circuit (M/T)- Is this related or another issue? Is it possibly a bad or loose eliminator?? (Also posted in C5 Tech)
Thx in advance.
Old Sep 11, 2006 | 03:35 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
There's always a first time for everything - I have not heard of a bad CAGS before - it is only a resistor and some connectors so there's not much that could go wrong with it. If you have checked that it is installed correctly (both sides plugged in), then I would suggest contacting the vendor you purchased it from.
Old Sep 11, 2006 | 04:01 PM
GRAY BEARD's Avatar
GRAY BEARD
Check you installation to make sure all of the wires are ok. Sometimes they can rub through and short if on a sharp edge. Also make sure they are not on anything hot.
Old Sep 11, 2006 | 04:07 PM
Jumper's Avatar
Jumper
I got that same code not too long ago. It would come and go. It was especially strange b/c I had my car tuned some time after installing the CAGS eliminator and CAGS was completely removed from the PCM. Tried testing the battery and the alternator b/c the manual says that code can be thrown when one of those starts to go bad. After exhausting those potential problems, I jacked up the car and removed the CAGS eliminator. Guess what?!?! The code never came back.
Old Sep 11, 2006 | 05:23 PM
hotwheels57's Avatar
hotwheels57
Some have complained that their CAGS eliminator melted due to the heat of the transmission...that's why I suggest using a #10 or #12 ADEL rubber insulated clamp instead of the plastic tie wrap.
To Bad CAGS Eliminator??
