Run Flats are Gone!
The reports from the forum and elsewhere are true - the non-run flats make a remarkable difference in the handling and overall feel of the car.
My plans were to replace the R/F's with the F1 GS-D3's over the winter. This is probably a dumb question, but do you keep the pressure sensors with the non-run flats?
What was the total price for the changeover?
Thanks,
I have seen quite a few C-5's with them on. Must be a good alternative.
completely, except that I have the GS-D3's (not that the PS-2's aren't great tires as well), and love 'em. But I've already managed to pick of a nail in the right rear
. The plug/repair kit I put together worked great, though
I left them in because if it was a slow leak the DIC might warn you in time to get off the road and save the tire. If it is a severe puncture, the tire will be history and the DIC will indicate a moot point.
When swapping the tires, make sure the installer putd the wheels back on in the original position so the sensors don't get screwed up. I was told by the installer that the right front needed to go back on the right front etc. I did not bring the car in, just the wheels and tires so I marked everything so the installer would get the tires on right.
Glad I read this, new BFG's for me.
Cliff
You are right. Everyone raves about how much better C5s ride without run flats. That is largely in part because the suspension was tuned to give an acceptable sports car ride with the very stiff run flats. When people put softer regular tires on, this results in a much softer ride, BUT handling suffers. Run flats have very extreme steering response due to the stiff sidewalls.
I am on my third set of OEM run flats (98,000 miles). My C5 rides like a luxury car compared to my 1964 VERT ! Besides, it is a sports car, if you want a luxury ride buy a luxury car ! You won't catch me changing a tire along the road (although I did on my Van recently, but I waited until a Police was behind me with his lights on), I have had a friend seriously injured changing a flat, it only has to happen once to you !
I would keep my TPS's in even with non-runflats. It gives you a warning if a slow leak is happening.
I know that Z06's with non-runflats catch grooves in the highway also. This is a function of tread width. C5 OEM runflats are extremely wide for their size, see below:
Here are the widths from Tire Rack:
The OEM Goodyear runflats are EXTREMELY WIDE for their size. The tread width is even wider than the 295 Z06 tires, here are the specs (tread width)
-Goodyear F1 GS EMT (275) 10.3 inches
-Goodyear Z06 (295) 10.2 inches
-Firestone (275) 8.6 inches
-Goodyear F1 GS D3 (275) 9.4 inches
-Goodyear F1 GS-2 EMT (285, 19 inch diameter) 9.2 inches
I am on my third set of OEM run flats (98,000 miles). My C5 rides like a luxury car compared to my 1964 VERT ! Besides, it is a sports car, if you want a luxury ride buy a luxury car ! You won't catch me changing a tire along the rode (although I did on my Van recently, but I waited until a Police was behind me with his lights on), I have had a friend seriously injured changing a flat, it only has to happen once to you !
thats very interesting. i wan the security of runflats but i want the grip of nice sticky tires....whats a good medium???
When time came to change them out I could not justify the extra $$$ just to avoid a flat. I can't remember the last time I got a flat in any vehicle I own. Just put together a repair kit with plugs, a small scissor jack and cheapo Walmart compressor and your ready to go.
All this talk about flats is ridiculous - if someone offered to give you a C5 with regular tires or a Z06 would not take it becuase you might get a flat?
Cliff
Excellent choice by Estreeter for picking the king of tires!
Keep in mind, the vast majority of flat tires are the result of a slow leak from a nail or screw. If you have the TPMS functional, you should never experience one of these flats on the road. However if you drive down the interstate 10-15 pounds low on pressure, you can quickly and easily destroy a non-runflat tire. Yes catastrophic tire failures do occur, but most of them are the result of running excessively low air pressure, often associated with a slow leak that the owner never noticed.
GUSTO
I don't want to carry sections of 2x4's to run the car up on to get it jacked up. By the time I put everything in the trunk that people suggest in event of an emergency my car would look like it belonged to Sanford and Son
