Chassis versus Engine dyno
Old Sep 13, 2006 | 06:13 PM
Tom Porter's Avatar
Tom Porter
Default Chassis versus Engine dyno
How much HP does a stock C5 lose from parasitic loss from the driveline (MN6). Lets say the factory rates my LS1 at 350hp, and a chassis dyno indicates 300hp or roughly 17% at the wheels. Does that mean that as you increase HP thru mods you will always be 50 hp short at the chassis dyno or is it the 17%? I is pitiful that I lay awake at night thinking of things like this.
Old Sep 13, 2006 | 06:40 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
17% (some say between 15 & 18%)
As power increases with modifications, the percentage, for the most part, retain the same drive train loss.
Other factors:
Change of gear ratio
Temperature and/or humidity at time of dyno
Old Sep 13, 2006 | 07:48 PM
AU N EGL's Avatar
AU N EGL
and the make of the dyno.
Some shops say the Mustang Dyno is more accurate other say the Dynojet gives higher numbers, but then must be corrected, even after the SAE correction factors.
Dynos are for tuning, nothing more.
Old Sep 13, 2006 | 08:34 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Amen to that. Dyno racing is fun, but there are so many variances and dyno tricks that can come into play that it's not even funny.
To Chassis versus Engine dyno
