Fuel Gauge Accuracy??
Old Sep 27, 2006 | 06:04 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by jrose7004
Like ALL GM vehicles it bottom half goes a lot quicker than the first half!
Couldn't of said it better, even the wife's Mailbu does it. I am bad about never letting it go to far below half anyways.
Old Sep 27, 2006 | 06:57 PM
Nick1's Avatar
Nick1
Actually I'm on my third tank of gas and the Vette is much more consistant than my '96 Camaro was, so at least it's an improvement. Thanks for all the great commets!
Old Sep 27, 2006 | 07:02 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Since they changed my fuel gauge, when it gets to E, I still have 5 gallons in the tank
Old Sep 27, 2006 | 08:26 PM
Blue Lion's Avatar
Blue Lion
Originally Posted by DPG
my gauge is screwy. as soon as i start my car, it may say full, then about 10 min later is down about just less than a 1/4. then 30 min later its back up again to the full mark. really weird stuff. not sure whats going on here.
You could have a problem with your fuel tank sending units. Both of mine were replaced and it's a common C5 issue. I'd be driving down the road with plenty of gas and the bells and whistles would go off and the fuel gauge would flatline. I'd sweat and get gas asap, and it would only accomodate a few gallons.
My C5's gauge now seems accurate either half of the tank. I had a 98 Monte Carlo and the last half of the tank would fly by.
Old Sep 27, 2006 | 09:46 PM
slayer6x6's Avatar
slayer6x6
My Camaro does the same thing, it drives me crazy!
Old Sep 27, 2006 | 10:30 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I always wondered why the first 1/2 lasted so much longer than the last 1/2 of tank until it was explained to me this way:
The float is in the tank and if the tank is completely full of gasoline the float naturally is at its highest point with gas not only below the float but all up around the float. It will actually remain at this forced highest position until the level of gasoline has dropped not only the initial amount but until the gas level drops enough for the float to relax away from the forced position against the very top of the tank. Remember that no matter how small the float is, it does occupy space in the tank and the gas guage does not detect any consumption of gas until the float actually starts to float rather than ride in the forced up position.
I hope that explanation is clearer than mud!
Old Sep 28, 2006 | 11:56 AM
fej's Avatar
fej
19 gallons ... did not know that. Think I have put 15.8 in mine once and thought to myself damn I only had 1.2 gallons left I agree the reading has to do with the shape of the tank and the volume of gas that sits in that smaller portion of the tank is not read differently by the fuel float, so your 20mpg goes quicker on that 2nd half heh. Found it to be the same in my camaro as well.
Fej
Old Sep 28, 2006 | 01:14 PM
SavPrato's Avatar
SavPrato
It's not a linear relationship. When the fuel guage float moves 50% in the tank, it doesn't mean that 50% of the fuel has been consumed. The tank is not symetrical as the fuel level goes down in the tank. You could also factor in additional fuel at fill-up due to fuel in the tank filler spout.
You should never get below 1/4 tank anyway (if at all possible).
Old Sep 29, 2006 | 09:55 PM
CyberGSDude's Avatar
CyberGSDude
Originally Posted by Zuti
My gauge seems to be fairly consistent throughout the range, however on fill up, the gauge does not reach the full mark, no matter how much I squeeze in there. Anuone else seen this? Zuti
Mine too! Always reads at 3/4 full. IS there a fix? Trying techron on the next fill up.
Old Sep 30, 2006 | 07:36 AM
02bluez28's Avatar
02bluez28
the Vette is much more consistant than my '02 Camaro was, so at least it's an improvement. Thanks for all the great commets![/QUOTE]
