Door Panel
Old Sep 27, 2006 | 06:08 PM
Logansar's Avatar
Logansar
Default Door Panel
Is it a common problem that the small insert fall off the door panel?
Mine has done it 2 times and I am looking for a fix.
Old Sep 27, 2006 | 06:12 PM
tigerman's Avatar
tigerman
mine just fell off last night and wont go back on, looks like a couple little plastic pieces broke off.........cheers
Old Sep 27, 2006 | 06:40 PM
vettes4fun's Avatar
vettes4fun
Very common, there about $5.00 each
Old Sep 27, 2006 | 06:41 PM
DeeGee's Avatar
DeeGee
Mine did that just at the weekend
I'm on my third
I need a mod to keep it attached to the car
Old Sep 27, 2006 | 06:46 PM
rcs128's Avatar
rcs128
Whew. I thought I was the only one shaming the rest of the vette community by driving around with mine missing... I know that on mine a few of the little tabs are broken off and I've just been too lazy to figure out a fix.
Old Sep 27, 2006 | 06:54 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Count me in, passenger side, put it back on and hasn't come of since though. If we had a smilie for "knock on wood" I would insert it here.
Old Sep 27, 2006 | 06:56 PM
DeeGee's Avatar
DeeGee
I just went with a strip of 3M double sided tape on the inside. Lets hope it hangs on this time
Old Sep 27, 2006 | 07:31 PM
Bounty Hunter 10's Avatar
Bounty Hunter 10
Default Vendors?
I've gone thru several sets as well. Seems like this would be a good item for some vendor to redesign and produce, but built from aluminum, cf, or any other stronger material. Possibly with a small logo or color matched to interior? I think many of us would purchase a set if it were a more durable design than the POS chevy provided.
Vendors?
Steve
Old Sep 28, 2006 | 09:55 AM
OUR97's Avatar
OUR97
After mine fell out a few times, I got new ones and used the double sided tape also. I used carpet tape. Seemes a bit stronger than the others.
Old Sep 28, 2006 | 10:25 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Just use a piece of tape to tighten up the area.
If you use duoble sided tape it would make it way more difficult to remove the cover and may cause you to break it.
Old Sep 28, 2006 | 11:40 AM
rpm462's Avatar
rpm462
Curious...has anyone tried velcro? If so, how did that work?
Old Sep 28, 2006 | 02:14 PM
Logansar's Avatar
Logansar
Default double side tape
I think I am going that route.... trim the other tabs off and "stick it" ... It seems the "tabs" are the common problem.
Old Sep 28, 2006 | 02:28 PM
Bill Tompley's Avatar
Bill Tompley
I tried velcro - Works great
Old Sep 28, 2006 | 03:19 PM
Never had it happen to mine, but there have been numerous reports posted here that it has happened to them.
Old Sep 28, 2006 | 04:36 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I buy six at a time. It seems that by now the aftermarket guys would have come up with something trick.
Old Sep 28, 2006 | 05:54 PM
stingray4me's Avatar
stingray4me
mine broke too. I had to glue on the red light on the drivers door panel too. The material is pulling away on one of my door panels where you would rest your arm.
Old Sep 28, 2006 | 06:10 PM
LoneStarFRC's Avatar
LoneStarFRC
Phil! Paging Phil at Elite Engineering! You there Phil? Ah yes, I can see it now. True 6061-T6 billet aluminum and anodized in several different colors. Hmmm, on second thought, maybe Titanium. Hmmm. You making notes here Phil?
Old Sep 28, 2006 | 06:18 PM
mrtoner's Avatar
mrtoner
I have done this and it works great! Can even re-use it a couple of times.
Old Sep 28, 2006 | 11:51 PM
racerguyz28's Avatar
racerguyz28
Default just buy new ones
Just by 2 of them from ecklers they are 4.95 each if 1 broke so will the other i paid 4.95 for the plug and 6.00 for shipping funny huh
To Door Panel
