Clb???
Old Sep 28, 2006 | 09:11 AM
luv4vettes's Avatar
luv4vettes
Default Clb???
One of the posts in here (do's and dont's) said spend the $50 and installa CLB. What is that???
Old Sep 28, 2006 | 09:12 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
column lock bypass. If you have a mn6 C5 you will need it eventually because your column will lock leaving you stranded somewhere. The fix from GM doesn't correct the problem 100% for the MN6. If you have a A4 then the recall will take carre of the problem.
Old Sep 28, 2006 | 09:15 AM
Mr. Wonderful's Avatar
Mr. Wonderful
From: Slower than a speeding bullet................ Fort Lauderdale, FL
Get it done... don't be one of those posting that they should have done it after it's too late
Old Sep 28, 2006 | 09:16 AM
DeeGee's Avatar
DeeGee
Your profile doesn't say if you have an A4.
2001 A4s on were not affected as they do not have a column lock. Some 2000 A4s were affected.
Old Sep 28, 2006 | 09:26 AM
luv4vettes's Avatar
luv4vettes
Default 2000 coupe
I have a 2000 coupe. Also i have been getting message Service Column lock.
Old Sep 28, 2006 | 10:36 AM
sgreen4067's Avatar
sgreen4067
Drive up to my house, I
ll install it for 50 bucks
To Clb???
