DIC Code Question
Old Sep 28, 2006 | 04:29 PM
New C5 Owner's Avatar
New C5 Owner
Cruising
Default DIC Code Question
I checked my codes today and I only had one show up. It was 99-HVAC BO361. I found out the meaning of the code "Left Actuator Feedback Short To GND". My question is what does this actually mean? Is this something I can fix myself and where on the car should I start to look? I also posted this on the tech forum but haven't got an answer yet. Thanks in advance for your help everyone.
Old Sep 28, 2006 | 09:38 PM
New C5 Owner
Cruising
anyone?
Old Sep 28, 2006 | 10:58 PM
racerguyz28's Avatar
racerguyz28
Default ground
Just letting you know some corvettes have bad grounding problems because the way GM set up the grounding system. I believe they only use 3 or 4 grounding points throughout the car. but maybe something isnt synced up disconnect the battery and connect it again in a couple seconds it should reset the system if its not in sync. If the code pops again bring it to a tuner see what they can do. If you bring it to a dealership they will hit you where it hurts. Good luck
Old Sep 28, 2006 | 11:31 PM
DeeGee's Avatar
DeeGee
What was the suffix?
If it was an H it may have been transitory. C means its still current
To DIC Code Question
