I just sold my 93 C4 vette and now iam looking to move up to a2002 C5 fast back or Z06, but i need to know the answers to these simple questions.
#1. what's the enternal differences between the LS1 engine vs. the Z06's LS6 Engine.
#2. Do they have the same INT,EX valve size?
#3. do both engines have a (5QT) engine oil capacity?
#4. do they share the same manual transmission?
#5. how dose both body styles weight?
thanks boonie.
you can email me at: mbbriggs@softcom.net
#6. how much can i expect to pay for a low mileage 02-04 Z06?
The Z06 block is somewhat different than the reg C5. It has windows cast into the lower block so there is less trubulence and air drag as the pistons are driven down, the intake and MAF are different, exhaust in the Z06 is very efficent and light. The Zis about 200-250 lbs less than coupe. Valve size I believe is the same but the Z has hollow valves and the exhaust valves are filled with liquid sodium alloy to transfer heat better. Billet hollow cam, upgraded pistons. My Z takes 6 1/2 gts of oil. The Z has a 6 speed, MN12, that is geared more for acceleration than the standard MN6 coupe tranny. You can get a nice low mile (6K) Z 2002-2004 for $31,000 to $34,000.
If you appreciate what you drive you will like the more rigid frame and better handling of the Z. The brakes work much better and the larger wheel/tires not only help handling they look better. The non Z51 C5 coupe in my opinion is way too softly sprung for a sports car but then again I grew up racing go-carts.
I have driven both cars and the Z is what I think a Corvette should have been all along. Do yourself a favor and get the Z06- I think resale value in years to come will more than return the extra you may pay now.
I believe there is some great reading material in the FAQ section that will get you up to speed on the differences between the C5 and the C5 Z06 also. My vote is definitely for the Z if you really like to drive!
Since the tech questions are answered I'll put in my .02. I've had a C5 Z51 and now a Z. I really was surprised at the power and handling difference in the 2 models. Drive them both back to back and your decision will be obvious.
To know all the differences in the specifications is good, but you simply must drive a Z06 to feel the difference. For me they just couldn’t put that on paper!
Not true.
A c5 will give you a nice smile and a warm tingly feeling.
A Z06 will leave you like you just drank about 8 cups of coffee, and needing a new pair of shorts after your first "spirited" drive.
I'm a young old man (59 years young) and drove an 05 Z51 glass top. For my first Corvette drive that was OK. Then I drove an '04 Z. Guess which one made me change my shorts and I bought? The Z is AWESOME!!!!!!!!!!!!!
