Halltech Question
Old Oct 5, 2006 | 04:47 PM
TacoMike82's Avatar
TacoMike82
Default Halltech Question
Just got my Stinger installed and the airbridge contacts the hoodliner enough to leave an indent when the hood is closed. Is this common or did I do something wrong? What makes me think the Honker doesn't have this problem...
Old Oct 5, 2006 | 05:00 PM
D C's Avatar
D C
USMC (retired)
It will leave a little indent, but not bad. Now if it is significant, then I say you did something wrong....but I am sure you did it just fine.
Old Oct 5, 2006 | 05:03 PM
02gt350's Avatar
02gt350
leaves a mark
Old Oct 5, 2006 | 05:43 PM
kingsey's Avatar
kingsey
Starting to get very interested in this intake. Is that red on a torch red by any chance?
Old Oct 5, 2006 | 06:03 PM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
I don't have pix, but mine looks just like 02gt350's picture. Just a small depression in the liner. A little agravating... but like the way it works.
Old Oct 5, 2006 | 06:09 PM
TomBoy's Avatar
TomBoy
Very common. Here is a picture with my stock OEM hood liner with a vinyl decal. It shows the indent. I did not like the finished look here to show my car so upgraded to a nicer embr. liner. It does not show the indent as bad as the liner is allot thicker.
Laurie
BEFORE REPLACED LINER
AFTER LINER REPLACED
Old Oct 5, 2006 | 06:34 PM
almondted's Avatar
almondted
St. Jude Donor '07-'08
Doesn't seem to be a problem, but here's mine!
Old Oct 5, 2006 | 07:32 PM
kingsey's Avatar
kingsey
How do u like the intakes performance and overall quality. Tough install?
Old Oct 5, 2006 | 08:19 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Mine leaves a very small indent, but I messed around and adjusted it a couple times, and got it to where it is almost not leaving any indent.
I am very happy with this Intake. Was a good compliment to the heads and cam I added aftward.
Old Oct 5, 2006 | 08:25 PM
hotrod03's Avatar
hotrod03
Got rid of mine. You can do damage to the hood everytime you shut the hood. Puts pressure on the hood, and can crack the paint and "that can't be good" Black wing is the way to go.
Old Oct 5, 2006 | 08:27 PM
nate25's Avatar
nate25
Had mine for a while now. Small indent but no problems at all!
Old Oct 5, 2006 | 08:31 PM
steve8's Avatar
steve8
Mine isn't anything close to this one. Like others have said, very small.
Old Oct 5, 2006 | 08:36 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Taco -
I helped a friend trim his halltech airbridge down a little so that is would sit down flush on the radiator shroud.
They still contact the hood liner though - does not seem to be a problem.
best regards -
mqqn
Old Oct 6, 2006 | 01:50 AM
TacoMike82's Avatar
TacoMike82
Thanks guys for your help, looks like I am about standard. Took it out today and must admit SOTP feel is there and it also sounds a little meaner, so I am happy with it, as long as it doesn't go damaging my hood.
Old Oct 6, 2006 | 09:55 AM
Dave68's Avatar
Dave68
Very simple install:
See
http://www.conceptualpolymer.com/corvette_c5_corner.htm
The performance results are in my sig, below.
Remember that the airbridge is larger than that of the stock design, so a small impression is normal.
Old Oct 6, 2006 | 10:59 AM
B-ras's Avatar
B-ras
Just installed mine last weekend...went smooth and easy. It definitely contacts the liner, but not so much that the hood is tougher to close. If it is, then I'd say something is wrong. You have some room for forward/backward adjustment where the airbridge meets the coupler to the TB, so you can get it to the point where the bridge sits low as possible over the radiator support.
My butt meter says maybe 10hp over stock 00 LS1 airbox. But the throttle response and sound are the real gains, IMO.
Old Oct 6, 2006 | 01:15 PM
txz06ce's Avatar
txz06ce
I have the same problem. Mine is not bad, but touches just enough that the friction is rubbing off the paint on my custom painted hoodliner.
To Halltech Question
