[Z06] Valve Noise
Old Sep 15, 2001 | 10:03 PM
turbo's Avatar
turbo
Default Valve Noise
I know this has been asked before, but is it considered normal on a Z06 to have some valve noise? I can sit in the car and @ idle I can hear a tapping noise and I can also hear it @ higher rpm's ,like a lifter/tappet sound. This car makes different sounds that my 2000 coupe and I'm just not sure whats normal for a Z ! also when I let the clutch out and leave it in neutral the rattling is loud and @ other times its not to bad. any input is appreciated.
these noises are driving me :(
[Modified by turbo, 9:03 AM 9/17/2001]
Old Sep 16, 2001 | 12:21 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Valve Noise (turbo)
Funny, the ls1 in my coupe does the same thing. I'm thinking about pulling the pushrods and checking them. Even though I'm under warrenty, I'm afraid to let Chevy touch it :eek:
Eric
Old Sep 17, 2001 | 12:58 AM
av8or3's Avatar
av8or3
Default Re: Valve Noise (66ImpalaLT1)
I have the same noises in mine and have discussed them here before.I've
been assured by many that they are normal,and I've come to accept that.
I don't notice them as much as I used to and the car runs fine.You can drown them out with the exhaust or the radio when you're just cruise'n. :yesnod:
Old Sep 17, 2001 | 11:07 AM
turbo's Avatar
turbo
Anyone else have this noise? :confused:
Old Sep 17, 2001 | 11:28 AM
Black2001Z06's Avatar
Black2001Z06
Yep. I too have posed this question here many times. Been told it is an attribute of the higher lift cam (and more agressive profile) in the LS6.
Old Sep 17, 2001 | 02:56 PM
orenc's Avatar
orenc
I have the same noises on my '01 Z06. I have also been told that they are normal, but they just don't sound good when your sitting at a light with your new $50k sports car.
Old Sep 17, 2001 | 08:36 PM
turbo's Avatar
turbo
Anyone else?
Old Sep 17, 2001 | 10:32 PM
rickvette's Avatar
rickvette
My 2001 Z06 has 1300 miles on it and is realitively quiet yet. Remember the Z06 uses different fuel injectors than the LS1 and some of what you are hearing is fuel injector "snap". The early vin 2001's have some piston slap in them as tGM didn't utilize coded pistons until aroung May, 2001. Piston slap is caused by tolerences in the bores of the engine block with non fitted or "non coded" pistons. I discussed this at Corvettes at Carlisle with two GM engineers. The piston slap will not harm the engine its just noisy, especially upon cold start and until the engine reaches full operating temperature.
The factory went to a coded or fitted piston assembly in late Apirl or early May 2001 to illeviate this problem. The new ring sets didn't appear until 2002 and all 2002 LS6 motors also included coded or fitted pistons.
:seeya :seeya :seeya :seeya :seeya :seeya :seeya :seeya :seeya :seeya
Old Sep 18, 2001 | 03:37 PM
Rwdyryd's Avatar
Rwdyryd
I had the valve noise in my 01 Z06, I was told it was "normal". I sold it & bought an 02 Z06, it has the same valve train noise, I had hpoed it would be a little quieter than the 01. I guess it's just the price we pay for extreme performance! :D
Bob
Old Sep 21, 2001 | 12:51 AM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Default Re: Valve Noise (Rwdyryd)
Both 01 and 02 LS6 engines will have slightly more valve noise than LS1s and the 02 LS6 will make a teensy-weensy more noise than the 01.
Why?
Simple. The camshaft profiles are more aggressive and when you open and close the valves more and quicker, there's a little bit of noise.
Keyrist you whiners have never *really* heard valve noise from a Corvette. 327/375s from back in 64-65 or mechanical lifter Big-Blocks...now THAT was valve noise--the joyful noise of America's Sports Car.
Old Sep 21, 2001 | 01:05 AM
Power Shifter's Avatar
Power Shifter
Default Re: Valve Noise (Hib Halverson)
Hib, On my first ride, the wonderfull memory's of my 64 365 came rushing back in. Oh, if only I was 18 again. Ric
Old Sep 21, 2001 | 11:51 AM
Zee Freak's Avatar
Zee Freak
St. Jude Donor '03-'05-'06
Thanks Hib. You rule :D
Old Sep 21, 2001 | 05:59 PM
vortech's Avatar
vortech
Default Re: Valve Noise (ZEE FREAK)
my 2002 does it also-I woundn't worry my 98Z28 with the LS1 did it also. as long as there is no oil on the plugs your laughing.
Old Sep 21, 2001 | 06:58 PM
mmorse's Avatar
mmorse
Default Re: Valve Noise (vortech)
Welcome to the wonderful world of the small block Chevy. Every Corvette I've owned had valve noise of one degree or another. Hib's right. If you think this is bad, listen to an old big block. Of course to some, this is not noise, this is music. :D
Old Sep 22, 2001 | 10:16 PM
z-u-later's Avatar
z-u-later
Default Re: Valve Noise (mmorse)
2002 Z06 here and the valves also dance a bit on mine.I too listed a post and was assured that it's just music the LS6 is accustomed to making.
Mine however is intermittent pending on engine tempature.It disappears at W.O.T. however the exhaust bleeds over the engine tone.
:yesnod: Enjoy the car :yesnod:
I always drive mine like I stole it...
To Valve Noise
