Stumbling on acceleration
Old Oct 7, 2006 | 05:40 PM
jnfigueroa's Avatar
jnfigueroa
Default Stumbling on acceleration
I just bought a C5 6 speed and noticed that when I start to accelerate from a complete stop or accelerate in a higher gear the engine will stumble then begins to accelerate. There is no codes showing.
I've read some other threads of this problem but none seem to explain anything in detail other than it could be fuel, electrical, air....
Old Oct 7, 2006 | 07:42 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
It could be any number of things. You could have a fouled spark plug, an clogged injector, bad sensor, etc. While it may not be throwing any codes it might be wise to check the small stuff first and if that isn't the problem I would take it to a trusted mechanic and have them give it a once over.
Old Oct 7, 2006 | 08:34 PM
jnfigueroa's Avatar
jnfigueroa
Thanks for the info. My plan for tomorrow was to take the plugs off and inspect and if needed replace them.
Old Oct 7, 2006 | 08:53 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Fuel Filter
Old Oct 7, 2006 | 10:23 PM
TA8088's Avatar
TA8088
Originally Posted by Herringchoker
Fuel Filter
Old Oct 7, 2006 | 11:07 PM
hardtop's Avatar
hardtop
Air filter did it to me.
Old Oct 8, 2006 | 04:33 AM
Could even be a bad tank of gas that you got.
Old Oct 17, 2006 | 07:25 PM
jnfigueroa's Avatar
jnfigueroa
Well...I ended up changing the plugs and while I was installing the plug wires back I happen to notice that on one of the wires, the insulation had completely worn through and exposing the core wire. I bought a new set of wires and sure enough....the car is purring like a kitten. I cannot beleive what a difference it made. It is so smooth on take-off and acceleration. That wire must have been shorting out
Old Oct 17, 2006 | 10:50 PM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Congratulations.
Old Oct 18, 2006 | 11:07 AM
2vettes2go's Avatar
2vettes2go
1st thing check the fuel pressure. might be a bad pump.
Old Oct 18, 2006 | 11:14 AM
DeeGee's Avatar
DeeGee
To Stumbling on acceleration
