Hypertech III ...worth getting?
Old Oct 7, 2006 | 08:09 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default Hypertech III ...worth getting?
I'm thinking about getting one of these. I don't race, but I wonder if there could be some gains. Once you set it do you often go back in and reprogram? Are they worth it?
Old Oct 7, 2006 | 09:42 PM
VetteDawg's Avatar
VetteDawg
Well...I've got one...but I'm weird.
I put the tune on, lowered the fans setting a little (I also changed my thermostat to a 178)...stiffened up the shifting...can't even remember if I did anything else. I didn't have the tune on long before I realized that I LIKED the car shifting like a Cadillac (smoothely and quietly). I'm a 'elbow on the console, chin in my hand' kind of cruiser.
I had to bring the car to the dealer for something so I took the tune off and had them reflash the car with the latest and greatest while it was there.
I've heard horror stories of people putting the tune on and it screwing up on them. I had no problems...but I've heard that your battery has to be 100%. Some have hooked up 2 batteries while tuning.
The majority on this forum would suggest a different tuner than the hypertech. Perhaps those in the know of them will chime in.
Old Oct 7, 2006 | 10:05 PM
$$$frumnuttin'
thanks, I was afraid of that..the horror stories. With my luck I would join that crowd! I depend on my C5 as a daily driver so taking a chance on screwing it up is out of the question.
Old Oct 7, 2006 | 10:15 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
I didn't have any reliability issues...but they aren't really worth the money. If you can get one used for around 100 they mignt be worth a shot for fans and such. But other wise, find a good tuner, and have them make the changes you want, or better yet, purchase efi-live or hp-tuners.
Old Oct 7, 2006 | 10:40 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Oct 7, 2006 | 11:39 PM
Bill Dearborn's Avatar
Bill Dearborn
Don't bother. Difference in Dyno test before and after was 2 HP. Might have gotten the same difference with no changes at all since Dyno accuracy is only +/-1% which means at 300 HP the reading can vary by 6 HP from one run to the next.
Bill
Old Oct 7, 2006 | 11:47 PM
vettes4fun's Avatar
vettes4fun
Nope, don't waste your money get a real tune
Old Oct 7, 2006 | 11:48 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
The fact, that as your profile says you have a '97 Coupe, is we only have the Hypertech to work with unless we dial up a custom tune!
I installed mine and made a few tweaks and changes and it absoloutly complemented the other bolt ons I did! I like it! and I felt the difference immediately!
Thanks,Matt
Old Oct 8, 2006 | 12:10 AM
NemesisC5's Avatar
NemesisC5
In my 99 M6, CAI, catback, off road X-pipe, 178* therrmostat I found it good for adjusting two parameters. Lower fan turn-on temps & raise rev limiter to 6600 rpm. The 6600 rpm allowed me to hold 3rd gear through the 1/4 mile lowering my ET by slightly less than a tenth & increase mph by almost 2. With the combo I dynoed 337rwhp & 335rwtq. With headers & wideband custom tune I only gained 7rwhp. I realize other cars have gained much more but this combo was pretty much optimized. My point is a "custom" tune might not give you big gains in all cases & a used Hypertech might be a bargain at $100.
Scott
Old Oct 8, 2006 | 01:52 AM
daneaux's Avatar
daneaux
You will WASTE your money and perhaps damage your Vette!
DO NOT buy a used ONE!
PM me regarding the purchase of a used one off the forum...
Old Oct 8, 2006 | 03:42 AM
Old Oct 8, 2006 | 10:14 AM
gredmer's Avatar
gredmer
If your car is stock then a tune is a waste of money.
My local Nationally known tuner told me not to bother with a tune until your do internal engine work or long tube headers.
Mine has shorty headers and Cat-back Corsa Indys and he recommended not wasting the money on a tune.
I bought a Hypertech for $150.00 on the forum and use it to tighten the shifts on my A4 and that worked very well.
Old Oct 8, 2006 | 03:44 PM
$$$frumnuttin'
As usual, many different opinions. Keep 'em coming!!
Yes, I have a 97 A4 coupe with a blackwing and B&B exhaust....looking to add a new air bridge and coupler, but the 97 year is tough to work with.
Old Oct 8, 2006 | 03:57 PM
vetred's Avatar
vetred
Scott
Well there it is! and you must not think that you are going to get where you want to go by simply "tuning" It won't happen. you start by doing just what you will read on these "threads" open up the intake, lower the temps, big exaust, and then you will NOTICE the differance the "tune" will give! Frankly, the hand held will do just about as much till you do Internals, Cam/ heads etc. etc. then you must do the "dyno tune!
Old Oct 8, 2006 | 05:02 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Hypertech is great for A4 cars primarily to tweak the shift firmness and lower the fans....after I did that, Off to the Vette Drs for longtubes etc. you'll get hooked on the tweaks. Worth it imo for the A4 particularly
Old Oct 8, 2006 | 05:08 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have had the HYPERTECH III, the PREDATOR and now a tune and depending on what you plan on for your car, I am going to agree with Chris (STANGKILLER) on this too. Spending a few extra hundred and getting a decent tune or a program for you to tune with is much better. If you are like the first reply to your post, I recommend a PREDATOR, you can do more, have a handheld that shows codes and real-time data and it is relatively the same price.
You are going to get many opnions, it really comes down to what you plan on doing with your car in the long run. Also, you can have tunes written for your PREDATOR tuner and you can flash it to your PCM. It isn't as good as a actual dyno type tune, but it does work.
Micah
Old Oct 8, 2006 | 05:13 PM
$$$frumnuttin'
Micah
Yes, all I am looking for is more hp and seat of the pants go power. My car runs extremely smooth and I can hear the air rushing through, but I want to get all I can before going inside the engine. LT headers and a new intake would be in the picture too, but those would be last. Yea, right!
To Hypertech III ...worth getting?
Old Oct 8, 2006 | 06:42 PM
mike348's Avatar
mike348
I use the predator tune on my 04, A4 car. I can take out my tune if I need to have warranty service. 13.09 ET. black wing and tune.
Old Oct 8, 2006 | 08:07 PM
BiggieBoy's Avatar
BiggieBoy
I had one.....Save your $$$$
Old Oct 8, 2006 | 08:18 PM
RTSVET's Avatar
RTSVET
I have a predator tuner model number U7198 which is for 99-02 ls1 cars I used it on my 02 and could feel the difference in the set of the pants for sure but i ended up haveing a dyno tune done.
the predator when used becomes vin locked to the car it was used on which i didn't know. I was told after i reinstalled the stock tune it could be used on other cars which is not the case. I dont need the predator anymore so if you are interested in one sent me a pm.
